Saltar al contenido principal
360fly 4K Lens Replacement
Qué necesitas
  1. 360fly 4K Lens Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
  2. 360fly 4K Lens Replacement: paso 2, imagen 1 de 1
    • Remove the two 5 mm screws from the bottom of the camera with a T4 screwdriver.
  3. 360fly 4K Lens Replacement: paso 3, imagen 1 de 2 360fly 4K Lens Replacement: paso 3, imagen 2 de 2
    • Gently pry the plastic ring from around the charging plate with the metal spudger.
    • Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
  4. 360fly 4K Lens Replacement: paso 4, imagen 1 de 1
    • Remove the five 2 mm screws using a T4 screwdriver.
    • Pull off the charging plate assembly.
  5. 360fly 4K Lens Replacement: paso 5, imagen 1 de 2 360fly 4K Lens Replacement: paso 5, imagen 2 de 2
    • Gently pry the plug off the port on the circuit board with a plastic opening tool.
    • Remove the four 2 mm screws using a T4 screwdriver.
    • Remove the circuit board from the device.
  6. 360fly 4K Lens Replacement: paso 6, imagen 1 de 3 360fly 4K Lens Replacement: paso 6, imagen 2 de 3 360fly 4K Lens Replacement: paso 6, imagen 3 de 3
    • Remove the five 4 mm screws around the battery assembly with a T4 screwdriver.
    • Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
    • Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
    • Potential for device damage: Do not puncture or bend the battery. Use a small amount of heat to assist in softening the adhesive if necessary.
  7. 360fly 4K Lens Replacement, SD Card: paso 7, imagen 1 de 1
    • Gently pry the plug from the motherboard and remove the motherboard from the assembly.
  8. 360fly 4K Lens Replacement: paso 8, imagen 1 de 1
    • Remove the three 3 mm screws from the circuit assembly with a T4 screwdriver.
  9. 360fly 4K Lens Replacement: paso 9, imagen 1 de 1
    • Gently pry out the plug from the circuit assembly.
  10. 360fly 4K Lens Replacement: paso 10, imagen 1 de 1
    • Press and release the SD card to remove it from the circuit assembly.
  11. 360fly 4K Lens Replacement, Lens: paso 11, imagen 1 de 1
    • Unscrew the five 3mm screws with a T4 screwdriver.
  12. 360fly 4K Lens Replacement: paso 12, imagen 1 de 1
    • Gently push against the lens module to remove it from the 360fly 4K assembly.
Conclusión
Jacob Herron
Miembro Desde 11/08/17
463 Reputación
3 Guías creadas
Equipo
IUPUI, Team S5-G3, Baechle Fall 2017 Miembro de IUPUI, Team S5-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G3
3 Miembros
3 Guías creadas
4 comentarios
Hi. Where to get a replacement lens as I am in need for this repair, but 360fly offer a full service for $150 and do not sell spare lenses. Thx
anguel nakov - Contestar
There is no info where to buy the replacement lens.
gelo3000 - Contestar
Anyone know about usb pinout? I lost my charger adapter
Nuri Can PEHLİVAN - Contestar
Hi.
I inadvertently found your question.
I have this same problem.
I've lost the charger, too, and now I'm looking for a chance to charge without a base, or a chance to buy a base.
Imants
Imants R -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 20
Todo El Tiempo: 1,590
