Saltar al contenido principal
2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement
Qué necesitas
  1. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement, Cabin Air Filter: paso 1, imagen 1 de 1
    • Open the glove compartment in the passenger seat area.
    • The cabin air filter is located behind the glove compartment.
  2. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 2, imagen 1 de 2 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 2, imagen 2 de 2
    • Carefully detach the support bar from the glove compartment.
  3. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 3, imagen 1 de 2 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 3, imagen 2 de 2
    • On the side on the glove compartment there is a sign to push inward.
    • Use both hands to push inward to release the plastic holders on both sides.
    • Carefully lower the glove compartment down.
  4. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 4, imagen 1 de 3 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 4, imagen 2 de 3 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 4, imagen 3 de 3
    • You will have access to the filter compartment and cover.
    • Pinch the right side of the filter cover and pull toward you; it should come out with ease.
    • Be aware of the signs on the cover when replacing it in Steps 7-9.
  5. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 5, imagen 1 de 3 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 5, imagen 2 de 3 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 5, imagen 3 de 3
    • Pull the compartment completely out.
  6. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 6, imagen 1 de 3 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 6, imagen 2 de 3 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 6, imagen 3 de 3
    • Pull out the old filter from the compartment.
  7. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 7, imagen 1 de 2 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 7, imagen 2 de 2
    • Grab your new filter and place it into the compartment.
    • On the side of the filter, there are signs of the direction the filter should be placed in the direction of airflow. If placed incorrectly, your A/C will not filter the air well.
    • Pinch to adjust the filter in the compartment.
  8. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 8, imagen 1 de 2 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 8, imagen 2 de 2
    • Insert the compartment back into the filter compartment.
    • Make sure you put the compartment upwards in the direction the arrow is pointing.
  9. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 9, imagen 1 de 2 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 9, imagen 2 de 2
    • Place the cover back on the filter compartment.
    • Follow the arrow to appropriately place the cover in place.
  10. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 10, imagen 1 de 3 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 10, imagen 2 de 3 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 10, imagen 3 de 3
    • Do not forget to attach the support bar back to the glove compartment.
    • You can close the glove compartment. The plastic holders should click back to place.
  11. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: paso 11, imagen 1 de 1
    • You have finally replaced the cabin air filter!
Conclusión
By the end of this guide you have successfully replaced the cabin air filter on a 2023 RAV4 XLE Hybrid. Enjoy your clean air!
2 personas más completaron esta guía.
Bryan Huinac
Miembro Desde 01/24/23
247 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 13
Ultimos 7 días: 69
Ultimos 30 días: 227
Todo El Tiempo: 1,441
