Saltar al contenido principal
2019 Honda Civic Spark Plugs Replacement
Qué necesitas
  1. 2019 Honda Civic Spark Plugs Replacement, Spark Plugs: paso 1, imagen 1 de 2 2019 Honda Civic Spark Plugs Replacement, Spark Plugs: paso 1, imagen 2 de 2
    • Use a wrench to remove the bolts on the top of the engine cover.
    • Remove the engine cover.
  2. 2019 Honda Civic Spark Plugs Replacement: paso 2, imagen 1 de 3 2019 Honda Civic Spark Plugs Replacement: paso 2, imagen 2 de 3 2019 Honda Civic Spark Plugs Replacement: paso 2, imagen 3 de 3
    • Detach the clamps of the wire holder to disconnect it.
    • Put a screwdriver under the small panel on the wire connector and lift the panel.
    • Separate the cable from the wire connector.
  3. 2019 Honda Civic Spark Plugs Replacement: paso 3, imagen 1 de 2 2019 Honda Civic Spark Plugs Replacement: paso 3, imagen 2 de 2
    • Use the wrench to remove the bolt that is placed beside the wire connector.
    • Simply pull out the connector.
  4. 2019 Honda Civic Spark Plugs Replacement: paso 4, imagen 1 de 3 2019 Honda Civic Spark Plugs Replacement: paso 4, imagen 2 de 3 2019 Honda Civic Spark Plugs Replacement: paso 4, imagen 3 de 3
    • Make sure the spark plug area is dry before removing the spark plug.
    • Attach the socket to the socket wrench.
    • Put the socket inside the cylinder head and twist the socket wrench to remove the spark plug.
  5. 2019 Honda Civic Spark Plugs Replacement: paso 5, imagen 1 de 1
    • Inspect the new spark plug to ensure that it is completely dry.
  6. 2019 Honda Civic Spark Plugs Replacement: paso 6, imagen 1 de 2 2019 Honda Civic Spark Plugs Replacement: paso 6, imagen 2 de 2
    • Remove the old spark plug and attach the new spark plug to the socket.
    • Place the socket back in the cylinder head and twist the socket wrench to install the spark plug.
  7. 2019 Honda Civic Spark Plugs Replacement: paso 7, imagen 1 de 1
    • Connect the wire back to the spark plug.
  8. 2019 Honda Civic Spark Plugs Replacement: paso 8, imagen 1 de 1
    • Place the engine cover over the engine and reinstall the bolts using the wrench.
Linea de Meta
3 personas más completaron esta guía.
Bouttia Oshrieh
Miembro Desde 07/07/20
238 Reputación
1 Guía escrita
Equipo
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 12
Ultimos 7 días: 52
Ultimos 30 días: 191
Todo El Tiempo: 8,333
