Saltar al contenido principal
2017 Toyota Corolla Engine Air Filter Replacement
Qué necesitas
  1. 2017 Toyota Corolla Engine Air Filter Replacement, Engine Air Filter: paso 1, imagen 1 de 3 2017 Toyota Corolla Engine Air Filter Replacement, Engine Air Filter: paso 1, imagen 2 de 3 2017 Toyota Corolla Engine Air Filter Replacement, Engine Air Filter: paso 1, imagen 3 de 3
    • Caution: Ensure that the vehicle is off for at least two minutes and is parked before working.
    • Pop the hood and locate the engine's air filter. It is the object circled in red.
  2. 2017 Toyota Corolla Engine Air Filter Replacement: paso 2, imagen 1 de 2 2017 Toyota Corolla Engine Air Filter Replacement: paso 2, imagen 2 de 2
    • To unclip the air filter cover, you must first take off this tube, connected to the top.
  3. 2017 Toyota Corolla Engine Air Filter Replacement: paso 3, imagen 1 de 2 2017 Toyota Corolla Engine Air Filter Replacement: paso 3, imagen 2 de 2
    • Undo the hinges at each side of the cover.
    • Put a little bit of pressure down and they should unclip easily.
  4. 2017 Toyota Corolla Engine Air Filter Replacement: paso 4, imagen 1 de 3 2017 Toyota Corolla Engine Air Filter Replacement: paso 4, imagen 2 de 3 2017 Toyota Corolla Engine Air Filter Replacement: paso 4, imagen 3 de 3
    • Shift the cover forward and it should come off. Have two hands on it, one at the front and the back to jimmy it out easier.
    • Do not worry about holding onto it after taking it off.
  5. 2017 Toyota Corolla Engine Air Filter Replacement: paso 5, imagen 1 de 2 2017 Toyota Corolla Engine Air Filter Replacement: paso 5, imagen 2 de 2
    • Keep the cover up enough to slide the air filter right out of the cover box.
  6. 2017 Toyota Corolla Engine Air Filter Replacement: paso 6, imagen 1 de 2 2017 Toyota Corolla Engine Air Filter Replacement: paso 6, imagen 2 de 2
    • Insert the engine air filter you've acquired into the previous air filter's slot. It should fit like a glove once slotted properly.
    • Ensure that the marked sides align properly, or else it won't fit no matter which way you put it.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 69
Todo El Tiempo: 276
