Saltar al contenido principal
2017 Toyota 4Runner Key Fob Battery Replacement
Qué necesitas
  1. 2017 Toyota 4Runner Key Fob Battery Replacement, Key Fob Battery: paso 1, imagen 1 de 3 2017 Toyota 4Runner Key Fob Battery Replacement, Key Fob Battery: paso 1, imagen 2 de 3 2017 Toyota 4Runner Key Fob Battery Replacement, Key Fob Battery: paso 1, imagen 3 de 3
    • Push the side button on the key fob to release the real key from the fob.
  2. 2017 Toyota 4Runner Key Fob Battery Replacement: paso 2, imagen 1 de 3 2017 Toyota 4Runner Key Fob Battery Replacement: paso 2, imagen 2 de 3 2017 Toyota 4Runner Key Fob Battery Replacement: paso 2, imagen 3 de 3
    • Insert the key into the same shaped slit at the bottom of the key fob.
    • Twist the key to the right.
    • Separate the two halves of the key fob.
  3. 2017 Toyota 4Runner Key Fob Battery Replacement: paso 3, imagen 1 de 3 2017 Toyota 4Runner Key Fob Battery Replacement: paso 3, imagen 2 de 3 2017 Toyota 4Runner Key Fob Battery Replacement: paso 3, imagen 3 de 3
    • Remove the circuit board from the inside of the fob.
  4. 2017 Toyota 4Runner Key Fob Battery Replacement: paso 4, imagen 1 de 3 2017 Toyota 4Runner Key Fob Battery Replacement: paso 4, imagen 2 de 3 2017 Toyota 4Runner Key Fob Battery Replacement: paso 4, imagen 3 de 3
    • Remove the battery gently with a nylon spudger.
    • Make sure you don't damage any of the three tabs that hold the battery in place.
  5. 2017 Toyota 4Runner Key Fob Battery Replacement: paso 5, imagen 1 de 3 2017 Toyota 4Runner Key Fob Battery Replacement: paso 5, imagen 2 de 3 2017 Toyota 4Runner Key Fob Battery Replacement: paso 5, imagen 3 de 3
    • Place a new battery gently back into the circuit board with the positive side of the battery facing up.
    • Make sure the tabs click into place.
  6. 2017 Toyota 4Runner Key Fob Battery Replacement: paso 6, imagen 1 de 3 2017 Toyota 4Runner Key Fob Battery Replacement: paso 6, imagen 2 de 3 2017 Toyota 4Runner Key Fob Battery Replacement: paso 6, imagen 3 de 3
    • Align the circuit board with the base of the fob case and gently press it back into place.
  7. 2017 Toyota 4Runner Key Fob Battery Replacement: paso 7, imagen 1 de 3 2017 Toyota 4Runner Key Fob Battery Replacement: paso 7, imagen 2 de 3 2017 Toyota 4Runner Key Fob Battery Replacement: paso 7, imagen 3 de 3
    • Align the top and base of the fob and snap it back into place.
  8. 2017 Toyota 4Runner Key Fob Battery Replacement: paso 8, imagen 1 de 3 2017 Toyota 4Runner Key Fob Battery Replacement: paso 8, imagen 2 de 3 2017 Toyota 4Runner Key Fob Battery Replacement: paso 8, imagen 3 de 3
    • Insert the key back into the fob.
Linea de Meta
Una persona más ha completado esta guía.
Nic
Miembro Desde 01/18/22
181 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 77
Todo El Tiempo: 2,401
