Saltar al contenido principal
2017 Honda Accord Headlight Replacement
Qué necesitas
  1. 2017 Honda Accord Headlight Replacement, Headlight: paso 1, imagen 1 de 3 2017 Honda Accord Headlight Replacement, Headlight: paso 1, imagen 2 de 3 2017 Honda Accord Headlight Replacement, Headlight: paso 1, imagen 3 de 3
    • Pull the Hood Latch lever inside the car, located under the steering wheel.
    • Lift the hood while pressing up on the lever under the front of the hood.
  2. 2017 Honda Accord Headlight Replacement: paso 2, imagen 1 de 2 2017 Honda Accord Headlight Replacement: paso 2, imagen 2 de 2
    • Lift up the hood prop rod and insert it into the hole on the underside of the hood.
  3. 2017 Honda Accord Headlight Replacement: paso 3, imagen 1 de 2 2017 Honda Accord Headlight Replacement: paso 3, imagen 2 de 2
    • Use a 1/4" ratcheting wrench and a 10mm socket to loosen the bolt on the negative terminal head.
    • Lift the terminal up off of the battery and place it to the side.
  4. 2017 Honda Accord Headlight Replacement: paso 4, imagen 1 de 1
    • Use the clip remover tool to pry the clip up to remove it.
  5. 2017 Honda Accord Headlight Replacement: paso 5, imagen 1 de 3 2017 Honda Accord Headlight Replacement: paso 5, imagen 2 de 3 2017 Honda Accord Headlight Replacement: paso 5, imagen 3 de 3
    • Use a 1/4" ratcheting wrench and a 10mm socket to remove the three bolts.
  6. 2017 Honda Accord Headlight Replacement: paso 6, imagen 1 de 1
    • Use a 1/4" ratcheting wrench, a 6" extension and a 10mm socket to remove the last bolt.
  7. 2017 Honda Accord Headlight Replacement: paso 7, imagen 1 de 2 2017 Honda Accord Headlight Replacement: paso 7, imagen 2 de 2
    • Gently pull the headlight out.
  8. 2017 Honda Accord Headlight Replacement: paso 8, imagen 1 de 2 2017 Honda Accord Headlight Replacement: paso 8, imagen 2 de 2
    • Press the tab on the connector and pull. Do this for all 4 connectors.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 94
Todo El Tiempo: 3,361
