Saltar al contenido principal
2017 Ford Escape Wiper Blades Replacement
Qué necesitas
  1. 2017 Ford Escape Wiper Blades Replacement, Wiper Blades: paso 1, imagen 1 de 2 2017 Ford Escape Wiper Blades Replacement, Wiper Blades: paso 1, imagen 2 de 2
    • Starting with the driver's side wiper blade, gently lift the wiper blade until it is in an upright position and locked into place.
    • The wiper blade should be able to stand on its own without any support.
  2. 2017 Ford Escape Wiper Blades Replacement: paso 2, imagen 1 de 3 2017 Ford Escape Wiper Blades Replacement: paso 2, imagen 2 de 3 2017 Ford Escape Wiper Blades Replacement: paso 2, imagen 3 de 3
    • Look for a clip/tab on the top of the wiper blade. Push the tab until it slides out of the metal arm and then the wiper blade should come right out of the metal arm.
    • Be careful so as to not bend the arm.
  3. 2017 Ford Escape Wiper Blades Replacement: paso 3, imagen 1 de 3 2017 Ford Escape Wiper Blades Replacement: paso 3, imagen 2 de 3 2017 Ford Escape Wiper Blades Replacement: paso 3, imagen 3 de 3
    • Unpackage a new wiper blade. (Please ensure that you purchase the correct type of wiper blades. The wiper blade brand that I have chosen for this guide is the Rain-X Latitude Wiper.)
    • After several tries and fails, I've determined the Rain-X Latitude wiper blade to be the best fit. Other brands do not come with an adapter.
  4. 2017 Ford Escape Wiper Blades Replacement: paso 4, imagen 1 de 3 2017 Ford Escape Wiper Blades Replacement: paso 4, imagen 2 de 3 2017 Ford Escape Wiper Blades Replacement: paso 4, imagen 3 de 3
    • The 2017 Ford Escape has a PTB (Push Tab Button) arm. The Latitude wipers come with a pre-attached adapter as well as another one in the package. Remove the pre-attached adapter.
    • This requires quite a bit of effort.
    • Refrain from using a screwdriver to pry the adapter out since you may damage the blade.
  5. 2017 Ford Escape Wiper Blades Replacement: paso 5, imagen 1 de 3 2017 Ford Escape Wiper Blades Replacement: paso 5, imagen 2 de 3 2017 Ford Escape Wiper Blades Replacement: paso 5, imagen 3 de 3
    • Install the new adapter ensuring the connector aligns with the blade assembly. The adapter must click for a secure fit.
  6. 2017 Ford Escape Wiper Blades Replacement: paso 6, imagen 1 de 1
    • The top of the adapter has a tiny black housing. Fit the top of the wiper arm into the housing and align the bottom of the adapter with the tabs on the arm. Press firmly until you hear a click. Finally the wiper blade is installed.
Linea de Meta
Maheshwerie Samaroo
Miembro Desde 07/07/20
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 21
Ultimos 30 días: 158
Todo El Tiempo: 9,725
