Saltar al contenido principal
2017-2022 Honda CR-V Reverse Light Bulb Replacement
Qué necesitas
  1. 2017-2022 Honda CR-V Reverse Light Bulb Replacement, Reverse Light Bulb: paso 1, imagen 1 de 2 2017-2022 Honda CR-V Reverse Light Bulb Replacement, Reverse Light Bulb: paso 1, imagen 2 de 2
    • Open the trunk.
  2. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: paso 2, imagen 1 de 1
    • Determine which bulb(s) needs to be replaced.
  3. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: paso 3, imagen 1 de 2 2017-2022 Honda CR-V Reverse Light Bulb Replacement: paso 3, imagen 2 de 2
    • Open the panel with a flathead screwdriver.
    • If you do not have a flathead screwdriver, anything with a flat surface should work.
  4. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: paso 4, imagen 1 de 2 2017-2022 Honda CR-V Reverse Light Bulb Replacement: paso 4, imagen 2 de 2
    • Hold down tab and remove the cable.
  5. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: paso 5, imagen 1 de 2 2017-2022 Honda CR-V Reverse Light Bulb Replacement: paso 5, imagen 2 de 2
    • Turn the plug to the left until you hear a click.
  6. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: paso 6, imagen 1 de 1
    • Pull the socket out of its housing.
  7. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: paso 7, imagen 1 de 1
    • Take the bulb out the socket.
  8. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: paso 8, imagen 1 de 1
    • Replace the bulb.
    • Make sure you use the Hella 921TB Bulb 921 12V 16W W2.1X9.5D T5.
  9. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: paso 9, imagen 1 de 1
    • Put the plug back into its original position.
  10. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: paso 10, imagen 1 de 1
    • Turn plug to the right until secure.
  11. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: paso 11, imagen 1 de 2 2017-2022 Honda CR-V Reverse Light Bulb Replacement: paso 11, imagen 2 de 2
    • Reinsert the cable.
  12. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: paso 12, imagen 1 de 2 2017-2022 Honda CR-V Reverse Light Bulb Replacement: paso 12, imagen 2 de 2
    • Reinsert the panel.
Conclusión
This guide tells you how to replace the bulb, and how to put everything back together
Una persona más ha completado esta guía.
Hashmat Jadoon
Miembro Desde 09/17/23
235 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 108
Todo El Tiempo: 464
