Saltar al contenido principal
2016 Nissan Versa Brake Light Replacement
Qué necesitas
  1. 2016 Nissan Versa Brake Light Replacement, Brake Light: paso 1, imagen 1 de 1
    • Turn off the vehicle and let it cool down for 10 minutes.
    • Open the trunk.
  2. 2016 Nissan Versa Brake Light Replacement: paso 2, imagen 1 de 3 2016 Nissan Versa Brake Light Replacement: paso 2, imagen 2 de 3 2016 Nissan Versa Brake Light Replacement: paso 2, imagen 3 de 3
    • Remove the two plastic pins holding the plastic trunk cover using the flathead screwdriver.
  3. 2016 Nissan Versa Brake Light Replacement: paso 3, imagen 1 de 3 2016 Nissan Versa Brake Light Replacement: paso 3, imagen 2 de 3 2016 Nissan Versa Brake Light Replacement: paso 3, imagen 3 de 3
    • Peel away the trunk cover to reveal the two bolts holding the lights.
  4. 2016 Nissan Versa Brake Light Replacement: paso 4, imagen 1 de 3 2016 Nissan Versa Brake Light Replacement: paso 4, imagen 2 de 3 2016 Nissan Versa Brake Light Replacement: paso 4, imagen 3 de 3
    • Using the 10 mm socket and socket wrench, remove the two bolts holding the lens.
  5. 2016 Nissan Versa Brake Light Replacement: paso 5, imagen 1 de 3 2016 Nissan Versa Brake Light Replacement: paso 5, imagen 2 de 3 2016 Nissan Versa Brake Light Replacement: paso 5, imagen 3 de 3
    • Gently pry open the lens using the flathead screwdriver.
    • Using your hands, pull away the lens slowly.
    • Don't use too much force to pull the lens out as it may disconnect the electric cord or break the lens.
  6. 2016 Nissan Versa Brake Light Replacement: paso 6, imagen 1 de 3 2016 Nissan Versa Brake Light Replacement: paso 6, imagen 2 de 3 2016 Nissan Versa Brake Light Replacement: paso 6, imagen 3 de 3
    • Using the Phillips #3 screwdriver, remove the two screws holding the bulbs.
  7. 2016 Nissan Versa Brake Light Replacement: paso 7, imagen 1 de 3 2016 Nissan Versa Brake Light Replacement: paso 7, imagen 2 de 3 2016 Nissan Versa Brake Light Replacement: paso 7, imagen 3 de 3
    • Gently take out the inner cover holding the bulbs.
    • Use both hands when separating the lens from the bulbs. Use one hand to hold the inner cover of the bulbs while the other holds the lens.
  8. 2016 Nissan Versa Brake Light Replacement: paso 8, imagen 1 de 2 2016 Nissan Versa Brake Light Replacement: paso 8, imagen 2 de 2
    • Take out the brake bulb by pushing it down and turning it counter-clockwise at the same time.
  9. 2016 Nissan Versa Brake Light Replacement: paso 9, imagen 1 de 2 2016 Nissan Versa Brake Light Replacement: paso 9, imagen 2 de 2
    • Put the new brake light in and secure it by pushing it down and turning it clockwise.
    • Test the new light by turning the car on before moving to the next step.
    • Don't forget to switch off the car once you finish testing the light.
Conclusión
Una persona más ha completado esta guía.
Abdi Ahmed
Miembro Desde 01/12/21
196 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 23
Ultimos 30 días: 60
Todo El Tiempo: 3,884
