Saltar al contenido principal
2016 Nissan Altima Key Fob Battery Replacement
Qué necesitas
  1. 2016 Nissan Altima Key Fob Battery Replacement, Battery: paso 1, imagen 1 de 3 2016 Nissan Altima Key Fob Battery Replacement, Battery: paso 1, imagen 2 de 3 2016 Nissan Altima Key Fob Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Slide the little switch up on the back of the key. While doing so, remove the physical key that is stored inside the fob by pulling away.
  2. 2016 Nissan Altima Key Fob Battery Replacement: paso 2, imagen 1 de 1
    • Insert a flathead screwdriver or prying tool into the small notch located at the bottom of the key fob.
    • Carefully rotate the flathead counterclockwise to pry apart the two halves of the fob.
  3. 2016 Nissan Altima Key Fob Battery Replacement: paso 3, imagen 1 de 1
    • Pry out the battery with a flathead to avoid skin contact with electrical components.
    • Make sure to avoid touching the motherboard.
  4. 2016 Nissan Altima Key Fob Battery Replacement: paso 4, imagen 1 de 1
    • Now carefully place the new battery onto the silver platter.
    • Keep in mind positive side of the battery will be facing downward, while negative side will be facing towards you.
  5. 2016 Nissan Altima Key Fob Battery Replacement: paso 5, imagen 1 de 1
    • Line up the parts in order to secure the key.
    • Press down until the case makes a "click" sound.
  6. 2016 Nissan Altima Key Fob Battery Replacement: paso 6, imagen 1 de 1
    • Finally, insert the physical key back into the fob to complete your replacement.
Conclusión
3 personas más completaron esta guía.
Giovanni Avalos
Miembro Desde 12/06/22
214 Reputación
1 Guía escrita
Equipo
1Guía Comentario
Great job , thanks . Sent wife info and believe it she figured it out, thanks.
Erik - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 20
Ultimos 30 días: 114
Todo El Tiempo: 6,141
