Saltar al contenido principal
2015 Nissan Pathfinder Rear Windshield Wiper Replacement
Qué necesitas
  1. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement, Rear Windshield Wiper: paso 1, imagen 1 de 2 2015 Nissan Pathfinder Rear Windshield Wiper Replacement, Rear Windshield Wiper: paso 1, imagen 2 de 2
    • Gently life the wiper up and away from the windshield in an upright position.
  2. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: paso 2, imagen 1 de 2 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: paso 2, imagen 2 de 2
    • Using your finger and thumb, lift the wiper blade upward from the base.
    • The wiper should be sticking out and away from the windshield.
  3. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: paso 3, imagen 1 de 3 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: paso 3, imagen 2 de 3 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: paso 3, imagen 3 de 3
    • Locate the pivot block at the end of the wiper arm that connects to the blade.
    • Pull the blade away with adequate force to remove the blade completely.
  4. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: paso 4, imagen 1 de 1
    • Acquire the replacement blade and remove the rubber yellow protector.
  5. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: paso 5, imagen 1 de 3 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: paso 5, imagen 2 de 3 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: paso 5, imagen 3 de 3
    • Locate the thin notch in the center of the replacement blade.
    • Locate the corresponding rounded port on the wiper arm.
    • Insert the notch into the arm and push together with mild force to attach the wiper blade to the arm.
    • When attaching the wiper blade to the arm, a clicking sound should be heard to ensure it is correctly assembled.
  6. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: paso 6, imagen 1 de 3 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: paso 6, imagen 2 de 3 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: paso 6, imagen 3 de 3
    • Gently fold the blade in and lay the wiper blade and arm back down on the windshield.
Linea de Meta
Katie
Miembro Desde 08/16/23
133 Reputación
1 Guía escrita
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 19
Todo El Tiempo: 254
