Introducción
This guide will discuss the process of replacing the interior dome lights of a 2015 Nissan Micra car. Replacing the light bulb inside the dome light is a simple enough task so your experience with cars is irrelevant. What is important however, is the knowledge on how to replace these lights. You will need a W5W lightbulb for your interior car light as well as an opening tool in case things get stuck. One thing to look out for is the heat of the lightbulb since you’ll be removing it with your hands. Just follow the steps and you’ll have bright interior lights in no time.
Qué necesitas
Remove the plastic covering for the interior dome light. using your hands or an opening tool.
