Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement
Qué necesitas
  1. 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement, Seat Adjustment Switch Battery: paso 1, imagen 1 de 2 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement, Seat Adjustment Switch Battery: paso 1, imagen 2 de 2
    • Remove a total of four covers on the seat (two in the front and two in the back).
  2. 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 2, imagen 1 de 2 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 2, imagen 2 de 2
    • Carefully remove both seat adjustment switches using a trim remover.
    • Don't force the seat switch out. If too much force is applied, the seat switch will get damaged.
  3. 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 3, imagen 1 de 3 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 3, imagen 2 de 3 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 3, imagen 3 de 3
    • Use the impact wrench with a 14mm socket to remove the bolts securing the seat. There are two in front and two in the back of the seat.
  4. 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 4, imagen 1 de 3 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 4, imagen 2 de 3 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 4, imagen 3 de 3
    • Remove both screws securing the plastic cover in front of the seat using a screwdriver.
    • Slide the cover to the right and remove the cover.
    • You may carefully lift the seat up and lean it against the back of the seats. This will make the process easier.
  5. 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 5, imagen 1 de 2 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 5, imagen 2 de 2
    • Remove the screw holding the cover of the right side of the seat using a screwdriver.
  6. 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 6, imagen 1 de 3 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 6, imagen 2 de 3 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 6, imagen 3 de 3
    • Remove the clip that is holding the cover using a trim remover.
    • Remove the clips from the back of the seat that are also holding the cover together.
  7. 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 7, imagen 1 de 3 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 7, imagen 2 de 3 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 7, imagen 3 de 3
    • Slide the cover into the front of the seat and remove both screws using a screwdriver.
  8. 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 8, imagen 1 de 3 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 8, imagen 2 de 3 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 8, imagen 3 de 3
    • Use a trim remover to remove all four clips that are holding the battery in place.
  9. 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 9, imagen 1 de 2 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 9, imagen 2 de 2
    • Push the plug away from the battery and remove the seat adjustment switch battery.
    • Don't press too hard on the plug or force the plug out. The plug will get damaged and will not function properly if not careful.
  10. 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 10, imagen 1 de 2 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 10, imagen 2 de 2
    • Insert the new battery into the plug and connect them.
    • Test the new battery to see if it functions properly.
  11. 2015 Infiniti Q50 Seat Adjustment Switch Battery Replacement: paso 11, imagen 1 de 1
    • Completed!
Conclusión
Jonathan Ruvalcaba
Miembro Desde 10/21/24
193 Reputación
1 Guía escrita
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 17
Ultimos 30 días: 46
Todo El Tiempo: 736
