Introducción
Replacing headlight bulbs can be tricky, and since it is all done by hand (with no tools) it is easy to not understand what to pull/rotate. This guide will explain the exact steps needed to successfully remove and replace the headlight bulbs on a 2014 Subaru Forester entirely by yourself.
Qué necesitas
Make sure you have the correct replacement part. For the specified model, the H11 Headlight Bulb is the stock-standard replacement bulb (found at any automotive store).
Una persona más ha completado esta guía.
