Saltar al contenido principal
2014 Chevy Cruze Headlight Bulb Replacement
Qué necesitas
  1. 2014 Chevy Cruze Headlight Bulb Replacement, Headlight Bulb: paso 1, imagen 1 de 1
    • Open the hood of your Chevy Cruze. The headlight bulbs are shown in the image.
  2. 2014 Chevy Cruze Headlight Bulb Replacement: paso 2, imagen 1 de 1
    • Put on rubber gloves.
    • Twist the headlight bulb counterclockwise until you can pull it from its socket.
  3. 2014 Chevy Cruze Headlight Bulb Replacement: paso 3, imagen 1 de 1
    • Using a prying tool, push the gray locking mechanism back until it is completely removed.
    • The locking mechanism can be removed by sliding it in the opposite direction from the headlight bulb.
  4. 2014 Chevy Cruze Headlight Bulb Replacement: paso 4, imagen 1 de 1
    • Pull the old headlight bulb from the green socket.
Conclusión
Caiden
Miembro Desde 03/19/21
109 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 28
Ultimos 30 días: 128
Todo El Tiempo: 7,522
