Saltar al contenido principal
2013-Present Nissan Sentra Windshield Wiper Blades Replacement
Qué necesitas
  1. 2013-Present Nissan Sentra Windshield Wiper Blades Replacement, Windshield Wiper Blades: paso 1, imagen 1 de 2 2013-Present Nissan Sentra Windshield Wiper Blades Replacement, Windshield Wiper Blades: paso 1, imagen 2 de 2
    • Measure the length of the wiper blade using the measuring tape or check in the owners manual for the proper size.
    • This is to make sure that you buy the right length size for your vehicle wiper blades.
  2. 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: paso 2, imagen 1 de 1
    • Gently lift up both wiper blades.
  3. 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: paso 3, imagen 1 de 3 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: paso 3, imagen 2 de 3 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: paso 3, imagen 3 de 3
    • Pinch both sides of the latch and lift it up to unlock the blade.
  4. 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: paso 4, imagen 1 de 3 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: paso 4, imagen 2 de 3 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: paso 4, imagen 3 de 3
    • Pull down the wiper blade to disengage the hook.
    • Raise the wiper blade along the arm to remove it.
  5. 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: paso 5, imagen 1 de 3 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: paso 5, imagen 2 de 3 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: paso 5, imagen 3 de 3
    • Retrieve the new wiper blade.
    • Pull the wiper blade down onto the arm.
    • Raise the wiper blade up, allowing it to attach to the hook.
  6. 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: paso 6, imagen 1 de 3 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: paso 6, imagen 2 de 3 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: paso 6, imagen 3 de 3
    • Gently push the latch onto the wiper blade.
    • You should hear a "click" sound when it is locked.
Conclusión
Repeat the steps on the other windshield wiper to fully complete the replacement.
Victor Kwan
Miembro Desde 01/08/24
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 33
Ultimos 30 días: 66
Todo El Tiempo: 459
