Introducción
If your 2013 Nissan Rogue car no longer responds to the keyless remote, it is most likely due to a dead battery, which needs to be replaced. I will show you how to remove the battery and replace it properly step by step.
It's important to realize that 2013 Nissan Rogue is a push-to-start vehicle and in order to start the car, the key must be in close proximity. Without a functioning battery, the car will not be able to receive signals from the keyless remote to know it is in proximity to start the car.
Qué necesitas
Remove the key from the keyring by pulling the button on the back of the keyring from right to left while pulling the loop at the top.
3 personas más completaron esta guía.
