Introducción
Is your 2013 Nissan Rogue Key Fob not working properly, or isn't working at all? It might be time to replace the battery, and while it's open, take the time to clean out the inside.
Fob batteries needs to be replaced every 3 years to work at maximum range and not sporadically fail.
This guide demonstrates how to replace the battery and clean out your 2013 Nissan Rogue Key Fob.
Qué necesitas
Slide the small tab on the back of your fob to the left.
While holding the tab to the left, pull the metal key out from the top of your fob.
Your fob should now be fully functional!
Una persona más ha completado esta guía.
2 comentarios
OMG… I wish I had read this before and attempted to take my key fob apart. I’ve got it all scraped up and ugly from them telling me to use a screwdriver….never mind just do exacty everything this post tells you. I had no problems opening the key fob once I read this article .
Trust me do as this tells you step by step. Just don’t use a screwdriver as another on the www will inform you to do.
Thank you so much for posting this key fob battery replacement info.
Thanks worked perfectly and as stated above don't use a screwdriver I also read that but thank goodness I didn't have one
