Introducción
This guide is to help demonstrate how to properly replace a 2013 Altima interior door handle.
The door handle is important because it allows you easy access to get in and out of your vehicle. With this problem, you will have to find alternatives to get out of your car or worse, overpay a company for a $20 fix. You will only need a flathead screwdriver, a 10 mm socket and wrench, and a new handle.
Qué necesitas
Use an opening tool or spudger to gently pry open the cover behind the door handle.
Use a 10 mm socket to remove the bolt under the handle cap.
Una persona más ha completado esta guía.
