Saltar al contenido principal
2013 Nissan Altima Interior Door Handle Replacement
Qué necesitas
  1. 2013 Nissan Altima Interior Door Handle Replacement, Interior Door Handle: paso 1, imagen 1 de 3 2013 Nissan Altima Interior Door Handle Replacement, Interior Door Handle: paso 1, imagen 2 de 3 2013 Nissan Altima Interior Door Handle Replacement, Interior Door Handle: paso 1, imagen 3 de 3
    • Use an opening tool or spudger to gently pry open the cover behind the door handle.
    • Use a 10 mm socket to remove the bolt under the handle cap.
  2. 2013 Nissan Altima Interior Door Handle Replacement: paso 2, imagen 1 de 3 2013 Nissan Altima Interior Door Handle Replacement: paso 2, imagen 2 de 3 2013 Nissan Altima Interior Door Handle Replacement: paso 2, imagen 3 de 3
    • Use an opening tool or spudger to pry the window and door lock assembly up and free from the frame.
    • Use a 10 mm socket to remove the single bolt underneath the control assembly.
  3. 2013 Nissan Altima Interior Door Handle Replacement: paso 3, imagen 1 de 3 2013 Nissan Altima Interior Door Handle Replacement: paso 3, imagen 2 de 3 2013 Nissan Altima Interior Door Handle Replacement: paso 3, imagen 3 de 3
    • There is another screw located underneath the long arm panel (to the left of the door handle), unscrew it.
  4. 2013 Nissan Altima Interior Door Handle Replacement: paso 4, imagen 1 de 1
    • Unhook the cables from the window control panel to take off the door.
  5. 2013 Nissan Altima Interior Door Handle Replacement: paso 5, imagen 1 de 1
    • Unscrew the three silver screws directly behind the door handle (Top, left, right).
  6. 2013 Nissan Altima Interior Door Handle Replacement: paso 6, imagen 1 de 3 2013 Nissan Altima Interior Door Handle Replacement: paso 6, imagen 2 de 3 2013 Nissan Altima Interior Door Handle Replacement: paso 6, imagen 3 de 3
    • Unhook the two wires that hook into the unlock/lock mechanisms.
  7. 2013 Nissan Altima Interior Door Handle Replacement: paso 7, imagen 1 de 2 2013 Nissan Altima Interior Door Handle Replacement: paso 7, imagen 2 de 2
    • Remove the old door handle.
  8. 2013 Nissan Altima Interior Door Handle Replacement: paso 8, imagen 1 de 2 2013 Nissan Altima Interior Door Handle Replacement: paso 8, imagen 2 de 2
    • Place and screw the new handle into place.
  9. 2013 Nissan Altima Interior Door Handle Replacement: paso 9, imagen 1 de 3 2013 Nissan Altima Interior Door Handle Replacement: paso 9, imagen 2 de 3 2013 Nissan Altima Interior Door Handle Replacement: paso 9, imagen 3 de 3
    • Hook the lock/unlock wires back into the door handle. (Handle will not work unless this step is complete.
  10. 2013 Nissan Altima Interior Door Handle Replacement: paso 10, imagen 1 de 2 2013 Nissan Altima Interior Door Handle Replacement: paso 10, imagen 2 de 2
    • Plug in the window control panel and place the panel back in its respectful place.
    • The door panel clips should goes into the holes and snap in when in place.
  11. 2013 Nissan Altima Interior Door Handle Replacement: paso 11, imagen 1 de 3 2013 Nissan Altima Interior Door Handle Replacement: paso 11, imagen 2 de 3 2013 Nissan Altima Interior Door Handle Replacement: paso 11, imagen 3 de 3
    • Insert the screw beneath the control panel and the screw to the right of the lock/unlock button.
  12. 2013 Nissan Altima Interior Door Handle Replacement: paso 12, imagen 1 de 3 2013 Nissan Altima Interior Door Handle Replacement: paso 12, imagen 2 de 3 2013 Nissan Altima Interior Door Handle Replacement: paso 12, imagen 3 de 3
    • Next, place both the door arm and window control panel in their place. The arm should snap in while the control panel sits flush in place.
  13. 2013 Nissan Altima Interior Door Handle Replacement: paso 13, imagen 1 de 3 2013 Nissan Altima Interior Door Handle Replacement: paso 13, imagen 2 de 3 2013 Nissan Altima Interior Door Handle Replacement: paso 13, imagen 3 de 3
    • Lastly, place the screw back in its respective place and tighten it with the rachet.
  14. 2013 Nissan Altima Interior Door Handle Replacement: paso 14, imagen 1 de 2 2013 Nissan Altima Interior Door Handle Replacement: paso 14, imagen 2 de 2
    • Finishing result: The older interior handle is in my hand, while the new interior handle is in place.
Linea de Meta
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 91
Todo El Tiempo: 1,945
