Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
2013 Lexus IS250 Front Dome Light Replacement
  1. 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: paso 1, imagen 1 de 2 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: paso 1, imagen 2 de 2
    • Open the glasses compartment located near the front dome light. This is usually a straightforward latch or button release.
    Pregunta a FixBot
    Agregar Comentario
  2. 2013 Lexus IS250 Front Dome Light Replacement: paso 2, imagen 1 de 3 2013 Lexus IS250 Front Dome Light Replacement: paso 2, imagen 2 de 3 2013 Lexus IS250 Front Dome Light Replacement: paso 2, imagen 3 de 3
    • Locate two housings inisde the compartment and gently pry them open using a flathead screwdriver. Take care not to damage the surrounding plastic.
    Pregunta a FixBot
    Agregar Comentario
  3. 2013 Lexus IS250 Front Dome Light Replacement: paso 3, imagen 1 de 3 2013 Lexus IS250 Front Dome Light Replacement: paso 3, imagen 2 de 3 2013 Lexus IS250 Front Dome Light Replacement: paso 3, imagen 3 de 3
    • Utilize a star screwdriver to remove the screws holding the front dome light in place. Ensure a steady hand to prevent any accidental dropping of screws.
    Pregunta a FixBot
    Agregar Comentario
  4. 2013 Lexus IS250 Front Dome Light Replacement: paso 4, imagen 1 de 3 2013 Lexus IS250 Front Dome Light Replacement: paso 4, imagen 2 de 3 2013 Lexus IS250 Front Dome Light Replacement: paso 4, imagen 3 de 3
    • With both hands wiggle both sides of the dome. Apply a bit of force at the top to release it from its position. Be cautious to not break the plastic clips securing it.
    Pregunta a FixBot
    Agregar Comentario
  5. 2013 Lexus IS250 Front Dome Light Replacement: paso 5, imagen 1 de 3 2013 Lexus IS250 Front Dome Light Replacement: paso 5, imagen 2 de 3 2013 Lexus IS250 Front Dome Light Replacement: paso 5, imagen 3 de 3
    • Inside, youll find two bulbs on both ends. Twist them to unlock and carefully remove.
    Pregunta a FixBot
    Agregar Comentario
  6. 2013 Lexus IS250 Front Dome Light Replacement: paso 6, imagen 1 de 2 2013 Lexus IS250 Front Dome Light Replacement: paso 6, imagen 2 de 2
    • Carefully remove bulb. Recommended to use gloves as it can be difficult to get a grip.
    Pregunta a FixBot
    Agregar Comentario
  7. 2013 Lexus IS250 Front Dome Light Replacement: paso 7, imagen 1 de 3 2013 Lexus IS250 Front Dome Light Replacement: paso 7, imagen 2 de 3 2013 Lexus IS250 Front Dome Light Replacement: paso 7, imagen 3 de 3
    • Replace these bulbs with LED alternatives, inserting them and securing by twisting.
    Pregunta a FixBot
    Agregar Comentario
  8. 2013 Lexus IS250 Front Dome Light Replacement: paso 8, imagen 1 de 1
    • Confirm that the bulbs are functioning by checking if the lights turn on. If not double check the alignment of the bulbs to ensure proper contact.
    • Carefully place the dome back into its original position. Ensure it aligns correctly with the plastic tips. Apply gentle pressure until it clicks back into place.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Christian
Miembro Desde 10/23/23
157 Reputación
1 Guía escrita
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 43
Todo El Tiempo: 915
