Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
2013 Infiniti G37 Dual Air Intakes Replacement
Qué necesitas
  1. 2013 Infiniti G37 Dual Air Intakes Replacement, Dual Air Intakes: paso 1, imagen 1 de 3 2013 Infiniti G37 Dual Air Intakes Replacement, Dual Air Intakes: paso 1, imagen 2 de 3 2013 Infiniti G37 Dual Air Intakes Replacement, Dual Air Intakes: paso 1, imagen 3 de 3
    • Pull the hood latch located inside the car under your remote holder.
    • Outside the car, find the lever under the actual hood, and squeeze and lift the hood.
    • Unscrew the mass airflow filter box from the frame with a Phillips #1 screwdriver.
    Pregunta a FixBot
  2. 2013 Infiniti G37 Dual Air Intakes Replacement: paso 2, imagen 1 de 3 2013 Infiniti G37 Dual Air Intakes Replacement: paso 2, imagen 2 de 3 2013 Infiniti G37 Dual Air Intakes Replacement: paso 2, imagen 3 de 3
    • Loosen the five bolts in the engine cover so you can have more space to access the mass airflow tubes.
    Pregunta a FixBot
  3. 2013 Infiniti G37 Dual Air Intakes Replacement: paso 3, imagen 1 de 3 2013 Infiniti G37 Dual Air Intakes Replacement: paso 3, imagen 2 de 3 2013 Infiniti G37 Dual Air Intakes Replacement: paso 3, imagen 3 de 3
    • Loosen the mass airflow sensor from the airflow tube and safely move it to a safe location out of the way.
    • Use vice grips to remove the clamp.
    Pregunta a FixBot
  4. 2013 Infiniti G37 Dual Air Intakes Replacement: paso 4, imagen 1 de 3 2013 Infiniti G37 Dual Air Intakes Replacement: paso 4, imagen 2 de 3 2013 Infiniti G37 Dual Air Intakes Replacement: paso 4, imagen 3 de 3
    • Loosen the last clamp, located at the head of the airflow tube, and give a firm tug towards you to free the entire piece.
    Pregunta a FixBot
  5. 2013 Infiniti G37 Dual Air Intakes Replacement: paso 5, imagen 1 de 3 2013 Infiniti G37 Dual Air Intakes Replacement: paso 5, imagen 2 de 3 2013 Infiniti G37 Dual Air Intakes Replacement: paso 5, imagen 3 de 3
    • Connect the mass airflow tube and tighten the clamps with a flathead screwdriver.
    Pregunta a FixBot
  6. 2013 Infiniti G37 Dual Air Intakes Replacement: paso 6, imagen 1 de 3 2013 Infiniti G37 Dual Air Intakes Replacement: paso 6, imagen 2 de 3 2013 Infiniti G37 Dual Air Intakes Replacement: paso 6, imagen 3 de 3
    • After all the clamps are tightened, place the mass airflow sensor into the tube and tighten with a Phillips #1 screwdriver.
    Pregunta a FixBot
Linea de Meta
Cordell Bowens
Miembro Desde 09/16/20
133 Reputación
1 Guía escrita
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 9
Ultimos 30 días: 61
Todo El Tiempo: 1,571
