Introducción
Although changing a car battery is a very simple procedure, you must take all necessary safety precautions. This is a detailed tutorial on changing an automobile battery.
Qué necesitas
To open up the hood of the car, locate the latch at the front bottom left side of the drivers side and pull it.
Push the lever underneath the center of the hood of the car to lift the hood up.
Use a 10mm wrench to loosen the nut on the negative terminal, then twist and pull the cable gently to detach it from the battery. Secure the cable away from the battery to avoid accidental contact.
Repeat the same process with the positive terminal. Lift the cover up and use a 10mm wrench to loosen the nut on the positive terminal then twist and pull the cable gently to detach it from the battery.
2 personas más completaron esta guía.
