Saltar al contenido principal
2013 Dodge Charger Windshield Wiper Replacement
  1. 2013 Dodge Charger Windshield Wiper Replacement, Windshield Wipers: paso 1, imagen 1 de 3 2013 Dodge Charger Windshield Wiper Replacement, Windshield Wipers: paso 1, imagen 2 de 3 2013 Dodge Charger Windshield Wiper Replacement, Windshield Wipers: paso 1, imagen 3 de 3
    • Pull the wiper blade arm away from windshield until it is locked in place and pointing directly away from the windshield.
  2. 2013 Dodge Charger Windshield Wiper Replacement: paso 2, imagen 1 de 3 2013 Dodge Charger Windshield Wiper Replacement: paso 2, imagen 2 de 3 2013 Dodge Charger Windshield Wiper Replacement: paso 2, imagen 3 de 3
    • Rotate the wiper blade perpendicular to the wiper blade arm.
  3. 2013 Dodge Charger Windshield Wiper Replacement: paso 3, imagen 1 de 2 2013 Dodge Charger Windshield Wiper Replacement: paso 3, imagen 2 de 2
    • Pull the rigid part of the wiper blade away from the arm.
  4. 2013 Dodge Charger Windshield Wiper Replacement: paso 4, imagen 1 de 3 2013 Dodge Charger Windshield Wiper Replacement: paso 4, imagen 2 de 3 2013 Dodge Charger Windshield Wiper Replacement: paso 4, imagen 3 de 3
    • Push the wiper blade down the arm (directly toward the windshield).
    • Once the clip on the windshield wiper clears the hook on the arm, your windshield wiper is completely removed.
  5. 2013 Dodge Charger Windshield Wiper Replacement: paso 5, imagen 1 de 2 2013 Dodge Charger Windshield Wiper Replacement: paso 5, imagen 2 de 2
    • Position the new blade so the hook is pointing at the wiper attachment.
    • The hook will go over the top of the attachment.
  6. 2013 Dodge Charger Windshield Wiper Replacement: paso 6, imagen 1 de 3 2013 Dodge Charger Windshield Wiper Replacement: paso 6, imagen 2 de 3 2013 Dodge Charger Windshield Wiper Replacement: paso 6, imagen 3 de 3
    • Pull the blade down toward the end of the arm until it passes the hook.
    • Push the blade up into the hook until you hear a click. This tells you that the wiper is into position.
Linea de Meta
2 personas más completaron esta guía.
Noah Young
Miembro Desde 10/23/20
187 Reputación
1 Guía escrita
Equipo
Texas Tech, Team S9-G1, Cowan Fall 2020 Miembro de Texas Tech, Team S9-G1, Cowan Fall 2020
TTU-COWAN-F20S9G1
1 Miembro
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 565
