Saltar al contenido principal
2013 Acura ILX Mass Air Flow Sensor Replacement
Qué necesitas
  1. 2013 Acura ILX Mass Air Flow Sensor Replacement, Mass Air Flow Sensor: paso 1, imagen 1 de 1
    • Disconnect the battery terminals by first loosening them with a 10 mm wrench.
    • Always remove the negative terminal first to prevent shorting to ground and possibly causing shock or even a fire.
    • Make sure the car is off and the the key is out of the ignition.
  2. 2013 Acura ILX Mass Air Flow Sensor Replacement: paso 2, imagen 1 de 1
    • Squeeze the clip on the top side of the wiring connector and pull out to remove it.
    • Do not touch the connections with your fingers, it may bend the needles and cause malfunction.
  3. 2013 Acura ILX Mass Air Flow Sensor Replacement: paso 3, imagen 1 de 2 2013 Acura ILX Mass Air Flow Sensor Replacement: paso 3, imagen 2 de 2
    • With a Phillips screwdriver, unscrew the two bolts that hold the sensor in place.
    • Pull the sensor up slowly to take it out of its casing
  4. 2013 Acura ILX Mass Air Flow Sensor Replacement: paso 4, imagen 1 de 1
    • With a cloth towel, clean the surface from any dirt or oil.
    • Try not to have anything fall into the opening where the sensor is positioned.
  5. 2013 Acura ILX Mass Air Flow Sensor Replacement: paso 5, imagen 1 de 1
    • Insert the new sensor and secure it down using the Philips screwdriver.
  6. 2013 Acura ILX Mass Air Flow Sensor Replacement: paso 6, imagen 1 de 2 2013 Acura ILX Mass Air Flow Sensor Replacement: paso 6, imagen 2 de 2
    • Connect the wiring harness back on the sensor.
Conclusión
Your car is fixed! The new sensor will improve the performance of the vehicle.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 16
Todo El Tiempo: 744
