Saltar al contenido principal
2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement
Qué necesitas
  1. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement, Camera: paso 1, imagen 1 de 3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement, Camera: paso 1, imagen 2 de 3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement, Camera: paso 1, imagen 3 de 3
    • Mount the new camera in the space provided.
    • The camera routes through the bumper of the car and not the license plate.
  2. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: paso 2, imagen 1 de 3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: paso 2, imagen 2 de 3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: paso 2, imagen 3 de 3
    • Run the new wires through the holes provided, and cover with electrical tape.
    • The new cords will simply connect where the faulty wires were removed.
  3. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: paso 3, imagen 1 de 3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: paso 3, imagen 2 de 3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: paso 3, imagen 3 de 3
    • Coordinate the colored wires to keep the repair simple. Match the new wires to the existing wires through the splitter. Use a wire splitter to expose the wire.
    • Then simply connect the wires to the wires for reverse light.
  4. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: paso 4, imagen 1 de 1
    • The green wire is the camera connection or positive wire and the black is the ground.
    • This line should already be connected correctly because you should have only switched wires that connected to the camera.
  5. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: paso 5, imagen 1 de 1
    • Make sure that the reverse light is working properly when the car is in reverse.
  6. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: paso 6, imagen 1 de 1
    • Make sure the display is clear and working properly.
Conclusión
2 personas más completaron esta guía.
2 comentarios
The photos you show in steps 2 & 3 - is that the trunk only?
jrselinger24 - Contestar
Hello. I am trying to replace my camera. But not sure how to remove it or where to buy a replacement.
Jonathan Anderson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 36
Ultimos 30 días: 188
Todo El Tiempo: 13,195
