Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
2013-2016 Scion FR-S Cabin Air Filter Replacement
Qué necesitas
  1. 2013-2016 Scion FR-S Cabin Air Filter Replacement, Cabin Air Filter: paso 1, imagen 1 de 2 2013-2016 Scion FR-S Cabin Air Filter Replacement, Cabin Air Filter: paso 1, imagen 2 de 2
    • Sit in the passenger seat and open the glove box.
    • Remove all contents to avoid anything falling out during the process.
    Pregunta a FixBot
    Agregar Comentario
  2. 2013-2016 Scion FR-S Cabin Air Filter Replacement: paso 2, imagen 1 de 2 2013-2016 Scion FR-S Cabin Air Filter Replacement: paso 2, imagen 2 de 2
    • Press the release tabs on both sides of the glove box at the same time using both hands to disengage the stoppers.
    • The glove box will drop down further, giving access to the filter housing behind it.
    Pregunta a FixBot
    Agregar Comentario
  3. 2013-2016 Scion FR-S Cabin Air Filter Replacement: paso 3, imagen 1 de 2 2013-2016 Scion FR-S Cabin Air Filter Replacement: paso 3, imagen 2 de 2
    • Carefully slide or pull the glove box dampener—the small arm attached to the right side of the glove box—away from the glove box to disconnect it.
    Pregunta a FixBot
    Agregar Comentario
  4. 2013-2016 Scion FR-S Cabin Air Filter Replacement: paso 4, imagen 1 de 2 2013-2016 Scion FR-S Cabin Air Filter Replacement: paso 4, imagen 2 de 2
    • Press the tabs on the sides of the plastic air filter cover to remove it.
    Pregunta a FixBot
    Agregar Comentario
  5. 2013-2016 Scion FR-S Cabin Air Filter Replacement: paso 5, imagen 1 de 2 2013-2016 Scion FR-S Cabin Air Filter Replacement: paso 5, imagen 2 de 2
    • Pull the old cabin air filter straight out.
    • Be careful—dust and debris may fall out.
    • Take note of the airflow direction printed on the old filter to ensure correct installation of the new one.
    Pregunta a FixBot
    Agregar Comentario
  6. 2013-2016 Scion FR-S Cabin Air Filter Replacement: paso 6, imagen 1 de 1
    • Slide the new filter into the housing with the airflow arrows pointing down.
    • Make sure it's completely inserted and seated correctly.
    Pregunta a FixBot
    Agregar Comentario
  7. 2013-2016 Scion FR-S Cabin Air Filter Replacement: paso 7, imagen 1 de 1
    • Replace the plastic filter cover.
    Pregunta a FixBot
    Agregar Comentario
  8. 2013-2016 Scion FR-S Cabin Air Filter Replacement: paso 8, imagen 1 de 3 2013-2016 Scion FR-S Cabin Air Filter Replacement: paso 8, imagen 2 de 3 2013-2016 Scion FR-S Cabin Air Filter Replacement: paso 8, imagen 3 de 3
    • Push the glove box back up and snap the side stoppers back in.
    • Reconnect the dampener arm on the right side.
    • Put your items back in, close it up, and you’re done!
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
MrtacosI8
Miembro Desde 03/04/25
169 Reputación
1 Guía escrita
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 53
Todo El Tiempo: 551
