Saltar al contenido principal
2013-2018 Toyota RAV4 Windshield Wipers Replacement
Qué necesitas
  1. 2013-2018 Toyota RAV4 Windshield Wipers Replacement, Windshield Wipers: paso 1, imagen 1 de 3 2013-2018 Toyota RAV4 Windshield Wipers Replacement, Windshield Wipers: paso 1, imagen 2 de 3 2013-2018 Toyota RAV4 Windshield Wipers Replacement, Windshield Wipers: paso 1, imagen 3 de 3
    • Adjust wipers in an upright position.
    • Lay out microfiber cloths on the windshield.
    • This is optional.
  2. 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 2, imagen 1 de 3 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 2, imagen 2 de 3 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 2, imagen 3 de 3
    • Push the wiper blade downwards, and twist it counter-clockwise out of the hook.
  3. 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 3, imagen 1 de 2 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 3, imagen 2 de 2
    • Remove the wiper blade off the hook completely.
    • Place the hook on the windshield (or microfiber cloth) carefully to avoid windshield damage.
  4. 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 4, imagen 1 de 2 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 4, imagen 2 de 2
    • On the other side, push the blade towards the hook, allowing you to twist the wiper into position and tighten.
  5. 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 5, imagen 1 de 3 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 5, imagen 2 de 3 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 5, imagen 3 de 3
    • Pick up the wiper and twist the blade clockwise to remove it from the hook.
  6. 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 6, imagen 1 de 3 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 6, imagen 2 de 3 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 6, imagen 3 de 3
    • Make sure to have the appropriate wiper blade sizes: 16" wiper blades for the passenger's side and 26" blades for the driver's side.
    • Hook the driver's side blade into the opening.
    • Pull the blade away from the hook to tighten.
  7. 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 7, imagen 1 de 3 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 7, imagen 2 de 3 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 7, imagen 3 de 3
    • On the passenger side, place the hook inside the opening and push the blade towards the hook. Ensure tightness.
  8. 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 8, imagen 1 de 3 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 8, imagen 2 de 3 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 8, imagen 3 de 3
    • For the rear wiper, simply pull the tab towards you and extend the wiper blade.
  9. 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 9, imagen 1 de 3 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 9, imagen 2 de 3 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 9, imagen 3 de 3
    • Twist and pull the wiper blade towards you, releasing the blade from the wiper handle with ease.
  10. 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 10, imagen 1 de 3 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 10, imagen 2 de 3 2013-2018 Toyota RAV4 Windshield Wipers Replacement: paso 10, imagen 3 de 3
    • With a new blade, align the wiper handle and insert it into the blade.
    • Once inserted, snap the blade into the handle.
Conclusión
Keep your windshield wipers in great shape using this guide.
Jithin Bobby
Miembro Desde 01/15/24
181 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 11
Ultimos 30 días: 63
Todo El Tiempo: 137
