Introducción
In this guide, I will show all the necessary step on how to change the oil and oil filter in a 2013-present Nissan Rogue. This guide does require the vehicle to be raised by a jack and put on a jack stand to get under the car. If you do not know how to lift a car on a jack and use jack stands follow this guide.
Working under a vehicle can be very dangerous if you fail to take proper precautions. Follow all instructions carefully, and do not attempt to take shortcuts or "make do" with missing or poorly maintained equipment. If you're not sure how to proceed, get some help from a more experienced fixer.
AT NO POINT during this procedure should you get underneath the vehicle when it's supported only by a jack. Make sure the vehicle rests securely on jack stands before getting underneath it.
You can also follow this guide to safely raise your vehicle with ramps rather than with a hydraulic jack.
Consult your vehicle owner manual to ensure that you use the correct oil for your engine.
Qué necesitas
On a flat, level surface, position the jack behind the front driver-side wheel so that it pushes the car up by the metal frame.
Place wheel chocks behind the front passenger-side wheel and the rear drive-side wheel.
Lift the car enough for you to be able to safely fit underneath it then fit the jack stand underneath it.
Gently lower the car so that it is resting all of its weight on the jack stand.
Slowly remove the oil filter by hand, or with a strap wrench if necessary.
Allow the oil to drain from the oil filter into the drain pan.
Once most of the oil has stopped leaking from the oil filter, remove it completely.
Place old oil filter to the side on some paper towels to avoid spill.
Enter the car.
On the dash board, use the right selector wheel and rotate it until the settings page is shown.
Press the selector peg.
With the selector peg, rotate the highlighted option to "maintenance."
Scroll to "service" and press the peg.
Scroll to "reset" and press the peg.
4 comentarios
The oil is not 5W30, it's OW20.
Cameron is indeed correct!
