Introducción
This guide will show you how to replace a door lock switch in a T3 (2010-2018) Volkswagen Touareg. An extra set of hands will make this repair much easier when removing the wiring from the back of the door panel. A lot of the panels that are to be removed contain brittle plastic clips, so proceed with caution.
Qué necesitas
Remove the door pull trim piece using a nylon offset v-notch prying tool.
5 personas más completaron esta guía.
