Saltar al contenido principal
2012 Nissan Sentra Rear Taillight Replacement
Qué necesitas
  1. 2012 Nissan Sentra Rear Taillight Replacement, Rear Taillight: paso 1, imagen 1 de 3 2012 Nissan Sentra Rear Taillight Replacement, Rear Taillight: paso 1, imagen 2 de 3 2012 Nissan Sentra Rear Taillight Replacement, Rear Taillight: paso 1, imagen 3 de 3
    • Open the trunk.
    • Locate the plastic large bolt behind the taillight.
    • This bolt holds the grey cover in place.
    • Remove the bolt with a flat head screw driver or wrench.
  2. 2012 Nissan Sentra Rear Taillight Replacement: paso 2, imagen 1 de 3 2012 Nissan Sentra Rear Taillight Replacement: paso 2, imagen 2 de 3 2012 Nissan Sentra Rear Taillight Replacement: paso 2, imagen 3 de 3
    • Peel back the grey cover to expose the back casing of the taillight.
  3. 2012 Nissan Sentra Rear Taillight Replacement: paso 3, imagen 1 de 3 2012 Nissan Sentra Rear Taillight Replacement: paso 3, imagen 2 de 3 2012 Nissan Sentra Rear Taillight Replacement: paso 3, imagen 3 de 3
    • Use a small wrench to loosen the two nuts securing the bolts.
    • Locate the group of wires in the center that connect to the bulbs.
  4. 2012 Nissan Sentra Rear Taillight Replacement: paso 4, imagen 1 de 3 2012 Nissan Sentra Rear Taillight Replacement: paso 4, imagen 2 de 3 2012 Nissan Sentra Rear Taillight Replacement: paso 4, imagen 3 de 3
    • Once the nuts are loose enough, use your fingers to remove the bolts easily.
  5. 2012 Nissan Sentra Rear Taillight Replacement: paso 5, imagen 1 de 3 2012 Nissan Sentra Rear Taillight Replacement: paso 5, imagen 2 de 3 2012 Nissan Sentra Rear Taillight Replacement: paso 5, imagen 3 de 3
    • Disconnect the plug by pressing a button located on the back.
    • This plug will disconnect the taillight from the car.
  6. 2012 Nissan Sentra Rear Taillight Replacement: paso 6, imagen 1 de 3 2012 Nissan Sentra Rear Taillight Replacement: paso 6, imagen 2 de 3 2012 Nissan Sentra Rear Taillight Replacement: paso 6, imagen 3 de 3
    • Loosen the sides of the taillight by gently pulling from side to side.
    • Pull the taillight straight out toward yourself in order to easily remove the wires from the small opening.
    • Grab the cord and pull the cord out through the small opening.
    • Place the damaged taillight aside.
  7. 2012 Nissan Sentra Rear Taillight Replacement: paso 7, imagen 1 de 3 2012 Nissan Sentra Rear Taillight Replacement: paso 7, imagen 2 de 3 2012 Nissan Sentra Rear Taillight Replacement: paso 7, imagen 3 de 3
    • Wipe down the vacant area and insert the new cord, from the new taillight, through the small opening.
  8. 2012 Nissan Sentra Rear Taillight Replacement: paso 8, imagen 1 de 3 2012 Nissan Sentra Rear Taillight Replacement: paso 8, imagen 2 de 3 2012 Nissan Sentra Rear Taillight Replacement: paso 8, imagen 3 de 3
    • Use your other hand to pull the wire inward and lock in the rubber grommet.
    • Make desired adjustments to the front of the taillight in order to have the best placement.
  9. 2012 Nissan Sentra Rear Taillight Replacement: paso 9, imagen 1 de 3 2012 Nissan Sentra Rear Taillight Replacement: paso 9, imagen 2 de 3 2012 Nissan Sentra Rear Taillight Replacement: paso 9, imagen 3 de 3
    • Grab the cord and connect it to the outlet.
    • This will allow the light bulbs in the new taillight to work.
  10. 2012 Nissan Sentra Rear Taillight Replacement: paso 10, imagen 1 de 2 2012 Nissan Sentra Rear Taillight Replacement: paso 10, imagen 2 de 2
    • Turn on your vehicle.
    • Put the car in reverse or step on the break to test out the new taillight.
    • If the rear lights turn on it means that the connection is intact.
    • Make sure to test both lights.
  11. 2012 Nissan Sentra Rear Taillight Replacement: paso 11, imagen 1 de 3 2012 Nissan Sentra Rear Taillight Replacement: paso 11, imagen 2 de 3 2012 Nissan Sentra Rear Taillight Replacement: paso 11, imagen 3 de 3
    • Place the small metal nuts back onto the screws and tighten them with a wrench.
    • Make sure the rubber grommet is intact so that the wires do not backflow into the taillight.
  12. 2012 Nissan Sentra Rear Taillight Replacement: paso 12, imagen 1 de 3 2012 Nissan Sentra Rear Taillight Replacement: paso 12, imagen 2 de 3 2012 Nissan Sentra Rear Taillight Replacement: paso 12, imagen 3 de 3
    • Pull the grey cover over the exposed metal and adjust it to its original place.
    • Place and push in the black plastic bolt in order to keep the grey cover from falling off.
Conclusión
This guide includes the reassembling steps so no need to backtrack!
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 19
Todo El Tiempo: 240
