Saltar al contenido principal
2012 Chevy Equinox Tail Light Bulb Replacement
Qué necesitas
  1. 2012 Chevy Equinox Tail Light Bulb Replacement, Tail Light Bulb: paso 1, imagen 1 de 3 2012 Chevy Equinox Tail Light Bulb Replacement, Tail Light Bulb: paso 1, imagen 2 de 3 2012 Chevy Equinox Tail Light Bulb Replacement, Tail Light Bulb: paso 1, imagen 3 de 3
    • Open the trunk of your car.
  2. 2012 Chevy Equinox Tail Light Bulb Replacement: paso 2, imagen 1 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: paso 2, imagen 2 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: paso 2, imagen 3 de 3
    • Remove the two plastic caps by placing a spudger in the bottom opening and gently prying upward.
  3. 2012 Chevy Equinox Tail Light Bulb Replacement: paso 3, imagen 1 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: paso 3, imagen 2 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: paso 3, imagen 3 de 3
    • Remove the two 6 mm Phillips #2 screws located underneath each of the plastic caps by twisting counterclockwise.
  4. 2012 Chevy Equinox Tail Light Bulb Replacement: paso 4, imagen 1 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: paso 4, imagen 2 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: paso 4, imagen 3 de 3
    • Hold the latch down firmly and pull the tail light cover off the vehicle.
    • You may have to apply a back and forth force to remove the cover.
  5. 2012 Chevy Equinox Tail Light Bulb Replacement: paso 5, imagen 1 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: paso 5, imagen 2 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: paso 5, imagen 3 de 3
    • Remove the light bulb socket from the vehicle by gently twisting and pulling it out of the tail light cover.
  6. 2012 Chevy Equinox Tail Light Bulb Replacement: paso 6, imagen 1 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: paso 6, imagen 2 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: paso 6, imagen 3 de 3
    • Twist the light bulb counterclockwise and pull to remove it from the socket.
  7. 2012 Chevy Equinox Tail Light Bulb Replacement: paso 7, imagen 1 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: paso 7, imagen 2 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: paso 7, imagen 3 de 3
    • Insert the new light bulb by gently pushing the light bulb into the socket and twisting clockwise.
    • When reassembling, make sure to align the tail light cover up to the back of the vehicle before pushing the cover back on.
Conclusión
Kelly Dixon
Miembro Desde 10/13/20
145 Reputación
1 Guía escrita
Equipo
Texas Tech, Team S9-G2, Cowan Fall 2020 Miembro de Texas Tech, Team S9-G2, Cowan Fall 2020
TTU-COWAN-F20S9G2
1 Miembro
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 46
Todo El Tiempo: 1,907
