Saltar al contenido principal
2012 BMW 3 Series Windshield Wiper Replacement
Qué necesitas
  1. 2012 BMW 3 Series Windshield Wiper Replacement, Windshield Wiper: paso 1, imagen 1 de 2 2012 BMW 3 Series Windshield Wiper Replacement, Windshield Wiper: paso 1, imagen 2 de 2
    • To begin, open the hood and make sure the broken wiper's body is completely positioned on the hood.
    • This is done to prevent scratches from developing throughout the repair process.
  2. 2012 BMW 3 Series Windshield Wiper Replacement: paso 2, imagen 1 de 2 2012 BMW 3 Series Windshield Wiper Replacement: paso 2, imagen 2 de 2
    • Use your fingers to pop the cover off that holds the wiper in place.
  3. 2012 BMW 3 Series Windshield Wiper Replacement: paso 3, imagen 1 de 2 2012 BMW 3 Series Windshield Wiper Replacement: paso 3, imagen 2 de 2
    • Use a back and forth motion to carefully remove the wiper blade from the wiper arm. and then pull it out.
  4. 2012 BMW 3 Series Windshield Wiper Replacement: paso 4, imagen 1 de 2 2012 BMW 3 Series Windshield Wiper Replacement: paso 4, imagen 2 de 2
    • Install the replacement wiper so that the slightly bent angle side faces the vehicle.
  5. 2012 BMW 3 Series Windshield Wiper Replacement: paso 5, imagen 1 de 2 2012 BMW 3 Series Windshield Wiper Replacement: paso 5, imagen 2 de 2
    • Check that the screw is aligned with the hole.
    • With a little pressure, slowly slide the new wiper into place.
  6. 2012 BMW 3 Series Windshield Wiper Replacement: paso 6, imagen 1 de 2 2012 BMW 3 Series Windshield Wiper Replacement: paso 6, imagen 2 de 2
    • Once it is positioned correctly, lock the cover to keep the blade in place.
    • If you hear a click, you will know you have succeeded.
    • Lower the windshield wiper carefully onto the windshield.
  7. 2012 BMW 3 Series Windshield Wiper Replacement: paso 7, imagen 1 de 1
    • Finally, test your wiper blades by spraying water or windshield wiper cleaner over your windshield and turning on the wipers.
    • You are done if they are wiping properly. If they appear to be loose, make sure they are securely attached before driving again.
Conclusión
Hafsa Yusuf
Miembro Desde 09/14/21
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 21
Ultimos 30 días: 81
Todo El Tiempo: 973
