Saltar al contenido principal
2012-2016 Honda CR-V Oil and Oil Filter Replacement
Qué necesitas
  1. 2012-2016 Honda CR-V Oil and Oil Filter Replacement, Oil and Oil Filter: paso 1, imagen 1 de 2 2012-2016 Honda CR-V Oil and Oil Filter Replacement, Oil and Oil Filter: paso 1, imagen 2 de 2
    • Open the hood by pulling the hood latch.
    • Oil may be hot if the engine has not cooled.
    • Keep vehicle in park and off unless otherwise noted.
    • Chock both back wheels with blocks of wood to prevent car from rolling.
  2. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 2, imagen 1 de 2 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 2, imagen 2 de 2
    • Let the vehicle cool for 15 minutes if needed. Clean the area around the oil cap. Remove the oil cap.
  3. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 3, imagen 1 de 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 3, imagen 2 de 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 3, imagen 3 de 3
    • Locate the dipstick and check oil level.
  4. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 4, imagen 1 de 1
    • Place the drain pain under the chassis and align with the drain bolt.
  5. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 5, imagen 1 de 1
    • Locate the drain bolt.
  6. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 6, imagen 1 de 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 6, imagen 2 de 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 6, imagen 3 de 3
    • Remove the drain bolt with a 17mm socket wrench, and completely drain the oil.
  7. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 7, imagen 1 de 1
    • Remove the oil filter with a 45mm oil filter socket.
  8. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 8, imagen 1 de 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 8, imagen 2 de 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 8, imagen 3 de 3
    • Replace the drain bolt with a new drain bolt gasket (crush washer); Honda Washer, Drain Plug (14MM) 94109-14000. Use the 17mm socket wrench to tighten.
  9. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 9, imagen 1 de 2 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 9, imagen 2 de 2
    • Install the new filter in place of the old filter. Hand tighten instead of using the oil filter wrench.
  10. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 10, imagen 1 de 2 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 10, imagen 2 de 2
    • Place the medium funnel and add new 0W-20 full synthetic engine oil. Add 4.2 quarts of oil.
  11. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 11, imagen 1 de 1
    • Replace the oil cap.
  12. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 12, imagen 1 de 1
    • Start the vehicle, and check for any leaks around the oil filter and oil drain plug.
    • Stop the vehicle and let the engine rest for 5 minutes.
  13. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 13, imagen 1 de 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 13, imagen 2 de 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: paso 13, imagen 3 de 3
    • Use the dip stick to double check oil level and add more if needed.
    • Make sure the oil level is in between the low and high marks on the dip stick. Replace the dip stick and close the hood.
    • Reset the oil life in the maintenance section of the vehicle computer.
Conclusión
6 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 14
Ultimos 7 días: 168
Ultimos 30 días: 688
Todo El Tiempo: 20,108
