Saltar al contenido principal
2011-Present Ford Explorer Driver Side Front Pillar Trim Replacement
Qué necesitas
  1. 2011-Present Ford Explorer Driver Side Front Pillar Trim Replacement, Driver's Side Front Pillar Trim: paso 1, imagen 1 de 3 2011-Present Ford Explorer Driver Side Front Pillar Trim Replacement, Driver's Side Front Pillar Trim: paso 1, imagen 2 de 3 2011-Present Ford Explorer Driver Side Front Pillar Trim Replacement, Driver's Side Front Pillar Trim: paso 1, imagen 3 de 3
    • Gently apply even force to separate the exterior pillar trim from the interior pillar trim.
    • The external pillar trim could break off but don't worry—a replacement part will be installed in its place.
  2. 2011-Present Ford Explorer Driver Side Front Pillar Trim Replacement: paso 2, imagen 1 de 3 2011-Present Ford Explorer Driver Side Front Pillar Trim Replacement: paso 2, imagen 2 de 3 2011-Present Ford Explorer Driver Side Front Pillar Trim Replacement: paso 2, imagen 3 de 3
    • Use a ratchet socket and an 8 mm socket attachment to remove the six bolts from the interior pillar trim.
    • If there is a small tab attached at the upper corner, detach it by gently lifting and separating it from the trim.
    • Bolts should be unscrewed and then carefully placed in a location to prevent loss or misplacing.
  3. 2011-Present Ford Explorer Driver Side Front Pillar Trim Replacement: paso 3, imagen 1 de 2 2011-Present Ford Explorer Driver Side Front Pillar Trim Replacement: paso 3, imagen 2 de 2
    • Remove the damaged interior pillar trim and clean surrounding areas.
    • Use a rag and glass cleaner to clean the pillar trim area.
    • Avoid contact with skin, eyes and clothing. Wash thoroughly after handling.
    • Remove any remaining residue from the window and metal. Use as much window cleaner as necessary.
  4. 2011-Present Ford Explorer Driver Side Front Pillar Trim Replacement: paso 4, imagen 1 de 3 2011-Present Ford Explorer Driver Side Front Pillar Trim Replacement: paso 4, imagen 2 de 3 2011-Present Ford Explorer Driver Side Front Pillar Trim Replacement: paso 4, imagen 3 de 3
    • Align the new interior pillar trim part precisely with the corresponding holes on the vehicle.
    • Ensure they are aligned precisely and apply pressure.
  5. 2011-Present Ford Explorer Driver Side Front Pillar Trim Replacement: paso 5, imagen 1 de 3 2011-Present Ford Explorer Driver Side Front Pillar Trim Replacement: paso 5, imagen 2 de 3 2011-Present Ford Explorer Driver Side Front Pillar Trim Replacement: paso 5, imagen 3 de 3
    • While maintaining downward pressure on the interior pillar trim, secure the six bolts into place.
    • Alternate one bolt at a time, bottom to top.
  6. 2011-Present Ford Explorer Driver Side Front Pillar Trim Replacement: paso 6, imagen 1 de 3 2011-Present Ford Explorer Driver Side Front Pillar Trim Replacement: paso 6, imagen 2 de 3 2011-Present Ford Explorer Driver Side Front Pillar Trim Replacement: paso 6, imagen 3 de 3
    • Align the small white head connections with the yellow points on the exterior trim, and then firmly snap the push tabs into place to secure the trim.
    • To guarantee a safe connection, gently press down after the white push tabs are aligned.
    • Remove the yellow markup sticker after inserting the tabs.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 19
Ultimos 30 días: 100
Todo El Tiempo: 561
