Saltar al contenido principal
2011 Volkswagen Eos Headlight Bulb Replacement
Qué necesitas
  1. 2011 Volkswagen Eos Headlight Bulb Replacement, Headlight LED: paso 1, imagen 1 de 1
    • Open the hood latch.
  2. 2011 Volkswagen Eos Headlight Bulb Replacement: paso 2, imagen 1 de 1
    • Pull the lever up to unlatch the hood.
  3. 2011 Volkswagen Eos Headlight Bulb Replacement: paso 3, imagen 1 de 1
    • Pull up the retainer clip, pushing up towards the front of the car.
  4. 2011 Volkswagen Eos Headlight Bulb Replacement: paso 4, imagen 1 de 1
    • Remove the plastic cover and place it off to the side.
  5. 2011 Volkswagen Eos Headlight Bulb Replacement: paso 5, imagen 1 de 1
    • Unscrew the bulb casing.
  6. 2011 Volkswagen Eos Headlight Bulb Replacement: paso 6, imagen 1 de 1
    • Pull the non-functional halogen bulb from the casing. This may take considerable force.
    • Be sure to have nylon gloves for this step!
  7. 2011 Volkswagen Eos Headlight Bulb Replacement: paso 7, imagen 1 de 1
    • Insert the new halogen bulb into the casing.
  8. 2011 Volkswagen Eos Headlight Bulb Replacement: paso 8, imagen 1 de 1
    • Insert bulb casing back into the socket.
  9. 2011 Volkswagen Eos Headlight Bulb Replacement: paso 9, imagen 1 de 1
    • Place the plastic cover back into the clips.
  10. 2011 Volkswagen Eos Headlight Bulb Replacement: paso 10, imagen 1 de 1
    • Close retainer clip by pushing down towards the bottom of the car to secure.
Conclusión
With the completion of the guide, your headlight LED should be working.
Una persona más ha completado esta guía.
Adam Malmquist
Miembro Desde 10/26/21
181 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 29
Ultimos 30 días: 127
Todo El Tiempo: 3,997
