Saltar al contenido principal
2011 Kia Sorento Windshield Wipers Replacement
Qué necesitas
  1. 2011 Kia Sorento Windshield Wipers Replacement, Windshield Wipers: paso 1, imagen 1 de 1
    • Pull up both front wiper blade arms from the windshield.
    • They should be pointed up and will stay without being held in place.
  2. 2011 Kia Sorento Windshield Wipers Replacement: paso 2, imagen 1 de 2 2011 Kia Sorento Windshield Wipers Replacement: paso 2, imagen 2 de 2
    • Take the driver's side wiper blade and pull it in a downward motion, releasing it from the wiper arm. Do the same for the passenger's side wiper blade.
    • Sometimes these joints can rust, especially if it has been a while since the last wiper blade replacement. If this is the case, just use a bit more force and it should release no problem.
  3. 2011 Kia Sorento Windshield Wipers Replacement: paso 3, imagen 1 de 2 2011 Kia Sorento Windshield Wipers Replacement: paso 3, imagen 2 de 2
    • Take the new driver's side wiper blade (24 inch wiper blade) and push it up onto the wiper arm joint. Do the same for the passenger's side wiper blade (20 inch wiper blade).
    • Different brands of wiper blades have slight differences in their attachment mechanisms, so if you have any issues, be sure to check the instructions on your new wiper blade's packaging.
  4. 2011 Kia Sorento Windshield Wipers Replacement: paso 4, imagen 1 de 1
    • Now that you have successfully installed the replacement wiper blades for the front windshield, gently push the wiper blade arms back down onto the windshield.
  5. 2011 Kia Sorento Windshield Wipers Replacement: paso 5, imagen 1 de 3 2011 Kia Sorento Windshield Wipers Replacement: paso 5, imagen 2 de 3 2011 Kia Sorento Windshield Wipers Replacement: paso 5, imagen 3 de 3
    • Pull up the rear windshield wiper from the windshield like you did for the front wipers.
    • It should be pointed towards you and stay in that position on its own.
    • Twist the wiper blade to have the actual blade piece face you, then pull it from the wiper arm.
  6. 2011 Kia Sorento Windshield Wipers Replacement: paso 6, imagen 1 de 3 2011 Kia Sorento Windshield Wipers Replacement: paso 6, imagen 2 de 3 2011 Kia Sorento Windshield Wipers Replacement: paso 6, imagen 3 de 3
    • Take your new rear wiper blade (11 inch wiper blade), and push it onto the wiper arm and rotate it back to face the windshield.
    • Once you have ensured that the wiper blade is fully attached, push the wiper arm back onto the windshield.
Conclusión
Once you ensure all wiper blades are fully locked into place, test them all to ensure they cover the proper areas needed to function correctly. If any of them are skipping or streaking during this test, return the wiper blade and reinstall a new one.
Wren Aris
Miembro Desde 10/01/22
133 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 112
