Saltar al contenido principal
2011 Jeep Liberty Hood Replacement
Qué necesitas
  1. 2011 Jeep Liberty Hood Replacement, Hood: paso 1, imagen 1 de 1
    • Open the hood of the Jeep by pulling the hood latch. This is placed right next to the driver's seat and to the left of the brake pedal.
  2. 2011 Jeep Liberty Hood Replacement: paso 2, imagen 1 de 3 2011 Jeep Liberty Hood Replacement: paso 2, imagen 2 de 3 2011 Jeep Liberty Hood Replacement: paso 2, imagen 3 de 3
    • Notice a latch located above the car's grill after popping the hood. Lift the hood by releasing the latch. After lifting the hood, notice a movable latch just above the wiper fluid container. There is a specific hole on the left side of the hood where you can hook the latch.
  3. 2011 Jeep Liberty Hood Replacement: paso 3, imagen 1 de 1
    • Disconnect the wind-shield fluid line on the left side of the hood.
  4. 2011 Jeep Liberty Hood Replacement: paso 4, imagen 1 de 1
    • Identify the four bolts which can be seen towards the extreme left (2 bolts) and extreme right (2 bolts) underneath the hood.
  5. 2011 Jeep Liberty Hood Replacement: paso 5, imagen 1 de 1
    • Remove the four bolts using a 13mm wrench and lift the hood out of place.
    • After replacing the old hood with the new hood, reverse the process; tighten back the four bolts and connect the wind-shield fluid line.
Conclusión
Daniel Strode
Miembro Desde 03/23/21
121 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 1,367
