Saltar al contenido principal
2011 Ford Focus Air Conditioning Refrigerant Replacement
Qué necesitas
  1. 2011 Ford Focus Air Conditioning  Refrigerant Replacement, Air Conditioning Refrigerant: paso 1, imagen 1 de 3 2011 Ford Focus Air Conditioning  Refrigerant Replacement, Air Conditioning Refrigerant: paso 1, imagen 2 de 3 2011 Ford Focus Air Conditioning  Refrigerant Replacement, Air Conditioning Refrigerant: paso 1, imagen 3 de 3
    • Turn the car on and the A/C to the maximum.
  2. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: paso 2, imagen 1 de 1
    • Open your car's hood.
  3. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: paso 3, imagen 1 de 2 2011 Ford Focus Air Conditioning  Refrigerant Replacement: paso 3, imagen 2 de 2
    • Locate the low-pressure charging port.
  4. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: paso 4, imagen 1 de 1
    • Remove the cap by turning it counter-clockwise.
  5. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: paso 5, imagen 1 de 2 2011 Ford Focus Air Conditioning  Refrigerant Replacement: paso 5, imagen 2 de 2
    • Connect the nozzle and hold the canister at a 3 o'clock angle.
    • Warning: Keep an eye on the PSI level. It should stay between 30 and 50, as going beyond 50 psi could cause the car's compressor to become damaged.
    • Lock and remove the canister if it is around 40 to prevent it from going to 50 psi.
    • Finally, start up the car. If the air conditioning is cooler, you'll know that it works!
Linea de Meta
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 100
Ultimos 30 días: 529
Todo El Tiempo: 5,260
