Saltar al contenido principal
2011-2013 Scion tC Radio Head Unit Replacement
Qué necesitas
  1. 2011-2013 Scion tC Radio Head Unit Replacement, Radio Head Unit: paso 1, imagen 1 de 2 2011-2013 Scion tC Radio Head Unit Replacement, Radio Head Unit: paso 1, imagen 2 de 2
    • Remove the dashboard panel around the radio head by pulling on the bottom of the unit.
  2. 2011-2013 Scion tC Radio Head Unit Replacement: paso 2, imagen 1 de 2 2011-2013 Scion tC Radio Head Unit Replacement: paso 2, imagen 2 de 2
    • Remove the wire header connected to the panel by pressing inward on the tabs.
  3. 2011-2013 Scion tC Radio Head Unit Replacement: paso 3, imagen 1 de 1
    • Remove the four #2 12mm screws securing the head unit in the housing
  4. 2011-2013 Scion tC Radio Head Unit Replacement: paso 4, imagen 1 de 2 2011-2013 Scion tC Radio Head Unit Replacement: paso 4, imagen 2 de 2
    • Remove each bundle of wires that is connected to the back of the head unit.
  5. 2011-2013 Scion tC Radio Head Unit Replacement: paso 5, imagen 1 de 2 2011-2013 Scion tC Radio Head Unit Replacement: paso 5, imagen 2 de 2
    • Locate the metal brackets on the side of the head unit.
    • Use a Philips head screwdriver, remove the three #2 25mm screws from both support brackets on the side of the head unit
  6. 2011-2013 Scion tC Radio Head Unit Replacement: paso 6, imagen 1 de 1
    • Screw the support brackets to the new radio head unit
    • Note that the brackets are unique to the car. They will not come with your new head unit.
Conclusión
2 personas más completaron esta guía.
Dylan Smith
Miembro Desde 05/01/15
143 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 8-2, Regan Spring 2015 Miembro de Cal Poly, Team 8-2, Regan Spring 2015
CPSU-REGAN-S15S8G2
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 29
Todo El Tiempo: 7,430
