Saltar al contenido principal
2011-2013 Scion tC Oil/Oil Filter Replacement
Qué necesitas
  1. 2011-2013 Scion tC Oil/Oil Filter Replacement, Oil/Oil Filter: paso 1, imagen 1 de 1
    • Open the spare tire compartment in the trunk of the vehicle by pulling up on the black tab.
  2. 2011-2013 Scion tC Oil/Oil Filter Replacement: paso 2, imagen 1 de 1
    • Locate the manufacturer supplied jack and jack handle in the spare tire compartment; these will be needed for the replacement.
    • This is an emergency jack, and is not safe to use for routine maintenance. Use a floor jack with a weight rating appropriate for your vehicle.
  3. 2011-2013 Scion tC Oil/Oil Filter Replacement: paso 3, imagen 1 de 1
    • Place the jack approximately 2 feet behind the passenger wheel tire at the shown location. Finger tighten the jack until snug against the frame.
    • It's best to avoid using the jack included with the car. If at all possible, use at least a 2 ton floor jack.
  4. 2011-2013 Scion tC Oil/Oil Filter Replacement: paso 4, imagen 1 de 1
    • Place the jack handle in the jack to begin lifting the car.
  5. 2011-2013 Scion tC Oil/Oil Filter Replacement: paso 5, imagen 1 de 1
    • Using two hands, turn the jack handle clockwise and raise the car.
  6. 2011-2013 Scion tC Oil/Oil Filter Replacement: paso 6, imagen 1 de 1
    • Raise the car until the jack stand can fit underneath the frame. Place the jack stand under the frame as close to the jack as possible.
  7. 2011-2013 Scion tC Oil/Oil Filter Replacement: paso 7, imagen 1 de 1
    • Lower the car onto the jack stand by turning the handle counterclockwise. Remove the jack once the load is taken off.
  8. 2011-2013 Scion tC Oil/Oil Filter Replacement: paso 8, imagen 1 de 1
    • Once the jack stand is securely in place locate the engine oil drain plug. This is most accessible by crawling on your back from the front of the car.
  9. 2011-2013 Scion tC Oil/Oil Filter Replacement: paso 9, imagen 1 de 1
    • Using the 14mm socket wrench, loosen the drain plug by turning counterclockwise until you can turn the plug by hand.
    • Be careful not to loosen all the way to avoid spilling oil.
  10. 2011-2013 Scion tC Oil/Oil Filter Replacement: paso 10, imagen 1 de 1
    • Once the plug is slightly loose, place the oil drain pan underneath the plug, remembering to account for the arc of the stream when placing the oil pan.
    • Continue to loosen the plug until oil begins to flow.
  11. 2011-2013 Scion tC Oil/Oil Filter Replacement: paso 11, imagen 1 de 1
    • Allow oil to drain freely until drops of oil are slowly coming from the drain. Then re-tighten the oil drain plug using the 14mm socket wrench.
    • Do not over-tighten the drain plug. Only apply approximately 20 lbs to the end of the wrench.
  12. 2011-2013 Scion tC Oil/Oil Filter Replacement: paso 12, imagen 1 de 1
    • Locate the oil filter. This is most accessible on your back from the front of the car. The filter should be about a foot closer to the front of the car from the oil drain plug.
  13. 2011-2013 Scion tC Oil/Oil Filter Replacement: paso 13, imagen 1 de 1
    • Using the 3/8 inch socket wrench with extension, loosen the oil filter by putting the extension in the square hole in the filter and turning counterclockwise.
  14. 2011-2013 Scion tC Oil/Oil Filter Replacement: paso 14, imagen 1 de 1
    • Place the oil drain pan directly under the filter. Fully loosen the filter by hand until you are able to remove it from the vehicle.
  15. 2011-2013 Scion tC Oil/Oil Filter Replacement: paso 15, imagen 1 de 3 2011-2013 Scion tC Oil/Oil Filter Replacement: paso 15, imagen 2 de 3 2011-2013 Scion tC Oil/Oil Filter Replacement: paso 15, imagen 3 de 3
    • Remove the paper filter from the filter cartridge; this is disposable. Use the flathead screwdriver to pry the o-ring off the cartridge.
Conclusión
Replace the oil filter with a new one. Once reinserted into the filter housing, relube the o-ring with some fresh oil and reinstall on the filter housing. To reassemble your device, follow these instructions in reverse order.
5 personas más completaron esta guía.
Lucas
Miembro Desde 05/07/15
223 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 8-2, Regan Spring 2015 Miembro de Cal Poly, Team 8-2, Regan Spring 2015
CPSU-REGAN-S15S8G2
5 Miembros
7 Guías creadas
Un comentario
That 3/8” extension removes a plug that allows for clearing the oil from the filter before removal. this does not remove the filter housing.
th4tguy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 34
Ultimos 30 días: 112
Todo El Tiempo: 27,362
