Saltar al contenido principal
2011-2013 Scion tC Front Dome Light Replacement
Qué necesitas
  1. 2011-2013 Scion tC Front Dome Light Replacement, Front Dome Light: paso 1, imagen 1 de 1
    • Remove the plastic covering of the lights by pulling it down quickly from the windshield side.
  2. 2011-2013 Scion tC Front Dome Light Replacement: paso 2, imagen 1 de 1
    • Disconnect the plastic header from system by pressing inward on the side tabs.
  3. 2011-2013 Scion tC Front Dome Light Replacement: paso 3, imagen 1 de 2 2011-2013 Scion tC Front Dome Light Replacement: paso 3, imagen 2 de 2
    • Turn blue knobs counter clockwise and pull to remove bulb housing.
  4. 2011-2013 Scion tC Front Dome Light Replacement: paso 4, imagen 1 de 2 2011-2013 Scion tC Front Dome Light Replacement: paso 4, imagen 2 de 2
    • Pull burnt bulb out of knob/housing.
    • When inserting the replacement, take note of the direction and polarity of the unit.
Conclusión
To reassemble the dome, follow these instructions in reverse order.
Una persona más ha completado esta guía.
Nick d'Alencon
Miembro Desde 05/01/15
346 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 8-2, Regan Spring 2015 Miembro de Cal Poly, Team 8-2, Regan Spring 2015
CPSU-REGAN-S15S8G2
5 Miembros
7 Guías creadas
Un comentario
I have been looking for how to remove the dome light assembly for awhile now! I felt that I was going to break the clips. Thanks for the great post!
Robert Killenberger - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 37
Todo El Tiempo: 3,696
