Saltar al contenido principal
2011-2013 Scion tC Car Battery Replacement
Qué necesitas
  1. 2011-2013 Scion tC Car Battery Replacement, Car Battery: paso 1, imagen 1 de 1
    • Begin by opening the hood of the car and locating the battery on the front of the driver side in the engine compartment
  2. 2011-2013 Scion tC Car Battery Replacement: paso 2, imagen 1 de 1
    • Using a socket wrench, loosen the 2 (5/16 inch) nuts on the top of the battery support bracket
    • Remove the bracket by lifting up
  3. 2011-2013 Scion tC Car Battery Replacement: paso 3, imagen 1 de 1
    • After removing the bracket, locate the supporting rod behind the battery
    • The rod is hooked on a hole in the metal behind the battery. Unhook the rod and remove it
  4. 2011-2013 Scion tC Car Battery Replacement: paso 4, imagen 1 de 2 2011-2013 Scion tC Car Battery Replacement: paso 4, imagen 2 de 2
    • Start with the negative terminal of the battery
    • Loosen the nut on the negative terminal with a 10mm socket wrench
    • Remove the wire by slightly twisting and pulling up
  5. 2011-2013 Scion tC Car Battery Replacement: paso 5, imagen 1 de 2 2011-2013 Scion tC Car Battery Replacement: paso 5, imagen 2 de 2
    • Remove the cap from the positive terminal of the battery
    • Using a 10mm socket wrench, loosen the nut on the positive terminal
    • Remove the wire from the positive terminal by slightly twisting and pulling up
    • Remove the battery by lifting it out of the engine compartment
Conclusión
Una persona más ha completado esta guía.
Travis Michael
Miembro Desde 05/08/15
140 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 8-2, Regan Spring 2015 Miembro de Cal Poly, Team 8-2, Regan Spring 2015
CPSU-REGAN-S15S8G2
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 45
Todo El Tiempo: 10,720
