Saltar al contenido principal
2011-2015 Kia Optima Interior Map Light Replacement
Qué necesitas
  1. 2011-2015 Kia Optima Interior Map Light Replacement, Interior Map Light: paso 1, imagen 1 de 1
    • Wedge the tip of the prying tool between the lens and the console.
    • Gently pry the lens off of the console.
  2. 2011-2015 Kia Optima Interior Map Light Replacement: paso 2, imagen 1 de 1
    • Separate the lens from the clips connecting the lens and the console.
  3. 2011-2015 Kia Optima Interior Map Light Replacement: paso 3, imagen 1 de 2 2011-2015 Kia Optima Interior Map Light Replacement: paso 3, imagen 2 de 2
    • Gently twist or pull away the bulb from the connection.
  4. 2011-2015 Kia Optima Interior Map Light Replacement: paso 4, imagen 1 de 2 2011-2015 Kia Optima Interior Map Light Replacement: paso 4, imagen 2 de 2
    • Insert the new bulb into the connection.
    • Some bulbs are polarity specific, so if at first the bulb does not work, try flipping it 180 degrees and connect it again.
  5. 2011-2015 Kia Optima Interior Map Light Replacement: paso 5, imagen 1 de 1
    • Reattach the lens back onto the console by clipping it back into place.
  6. 2011-2015 Kia Optima Interior Map Light Replacement: paso 6, imagen 1 de 1
    • Push the lens into the console. When you hear a click, the lens has been attached properly.
Linea de Meta
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 53
Todo El Tiempo: 1,599
