Saltar al contenido principal
2011-2016 Ford Super Duty Tail Light and Bulbs Replacement
Qué necesitas
  1. 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement, Tail Light and Bulbs: paso 1, imagen 1 de 2 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement, Tail Light and Bulbs: paso 1, imagen 2 de 2
    • Locate the two 8 mm screws that attach the taillight housing to the vehicle.
  2. 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: paso 2, imagen 1 de 2 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: paso 2, imagen 2 de 2
    • Using a socket and ratchet wrench, remove the two screws facing the inside of the bed that you located in Step 1.
  3. 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: paso 3, imagen 1 de 2 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: paso 3, imagen 2 de 2
    • Pull the light housing outward at an angle away from the truck.
  4. 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: paso 4, imagen 1 de 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: paso 4, imagen 2 de 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: paso 4, imagen 3 de 3
    • Twist the light socket in a counterclockwise motion to remove the bulbs.
  5. 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: paso 5, imagen 1 de 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: paso 5, imagen 2 de 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: paso 5, imagen 3 de 3
    • Insert a new bulb.
    • Place the light bulb socket back in the hole and turn clockwise until it's locked in place.
  6. 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: paso 6, imagen 1 de 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: paso 6, imagen 2 de 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: paso 6, imagen 3 de 3
    • Line up the taillight housing with the holes and guides, and push it into place.
  7. 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: paso 7, imagen 1 de 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: paso 7, imagen 2 de 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: paso 7, imagen 3 de 3
    • Use a socket and ratchet wrench to tighten the screws back into the taillight housing.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 37
Ultimos 30 días: 161
Todo El Tiempo: 3,723
