Saltar al contenido principal
2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement
Qué necesitas
  1. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement, Back-Up Light and Brake Light: paso 1, imagen 1 de 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement, Back-Up Light and Brake Light: paso 1, imagen 2 de 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement, Back-Up Light and Brake Light: paso 1, imagen 3 de 3
    • Make sure the car is off before you start your replacement. However, You don't have to disconnect the car battery.
    • Open the trunk first.
    • Using Phillips #2 screwdriver, remove the two 10 mm screws from the back & tail light.
  2. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: paso 2, imagen 1 de 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: paso 2, imagen 2 de 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: paso 2, imagen 3 de 3
    • Using both hands, carefully pull the brake & tail light off.
  3. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: paso 3, imagen 1 de 1
    • Here is the tail light assembly.
    • The left one is for the brake light.
    • The right one is for the back-up light.
  4. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: paso 4, imagen 1 de 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: paso 4, imagen 2 de 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: paso 4, imagen 3 de 3
    • Twist and turn the backup light to the right. And then pull it out.
    • Make sure not to touch the surface of the light bulb because it will break the light bulb easily.
  5. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: paso 5, imagen 1 de 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: paso 5, imagen 2 de 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: paso 5, imagen 3 de 3
    • Twist and turn the brake light to the right and pull it out.
    • Make sure not to touch the surface of the light bulb because it will break the bulb easily.
  6. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: paso 6, imagen 1 de 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: paso 6, imagen 2 de 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: paso 6, imagen 3 de 3
    • Replace the light bulbs.
    • Check that the light bulbs work first before replacing 10 mm screws.
Conclusión
2 personas más completaron esta guía.
Adrian Ng
Miembro Desde 09/18/21
196 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 25
Ultimos 30 días: 117
Todo El Tiempo: 4,504
