Saltar al contenido principal
2011-2017 Hyundai Accent Brake Light Replacement
  1. 2011-2017 Hyundai Accent Brake Light Replacement, Brake Light: paso 1, imagen 1 de 1
    • Open the trunk of the vehicle.
  2. 2011-2017 Hyundai Accent Brake Light Replacement: paso 2, imagen 1 de 3 2011-2017 Hyundai Accent Brake Light Replacement: paso 2, imagen 2 de 3 2011-2017 Hyundai Accent Brake Light Replacement: paso 2, imagen 3 de 3
    • View the side flap for whichever side has the dead bulb. (This is the left side view.)
    • Pull the flap up and locate the brake light.
    • The flap may need some extra force to open because the cutouts are typically not cut all the way through.
  3. 2011-2017 Hyundai Accent Brake Light Replacement: paso 3, imagen 1 de 2 2011-2017 Hyundai Accent Brake Light Replacement: paso 3, imagen 2 de 2
    • Twist the socket counterclockwise to gain access to the brake light.
  4. 2011-2017 Hyundai Accent Brake Light Replacement: paso 4, imagen 1 de 2 2011-2017 Hyundai Accent Brake Light Replacement: paso 4, imagen 2 de 2
    • Push down slightly and twist the bulb counterclockwise to remove the dead bulb.
    • Pay attention to the protrusions located on the bottom of the bulb. You will need to align these protrusions with the socket when inserting the new bulb.
  5. 2011-2017 Hyundai Accent Brake Light Replacement: paso 5, imagen 1 de 2 2011-2017 Hyundai Accent Brake Light Replacement: paso 5, imagen 2 de 2
    • Insert the new bulb into the socket and twist the bulb clockwise to secure it into place.
Conclusión
3 personas más completaron esta guía.
Un comentario
When I followed the instructions in reverse order as instructed to reassemble everything, I ended up with the old bulb back in the vehicle. Is there any way to fix this?
The Other Guy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 61
Ultimos 30 días: 291
Todo El Tiempo: 14,166
