Saltar al contenido principal
2010-Present Subaru Legacy Rear Door Reassembly
  1. 2010-Present Subaru Legacy Rear Door Reassembly, 2010-Present Subaru Legacy Rear Door Reassembly: paso 1, imagen 1 de 3 2010-Present Subaru Legacy Rear Door Reassembly, 2010-Present Subaru Legacy Rear Door Reassembly: paso 1, imagen 2 de 3 2010-Present Subaru Legacy Rear Door Reassembly, 2010-Present Subaru Legacy Rear Door Reassembly: paso 1, imagen 3 de 3
    • Insert the metal ball into the plastic door pull handle assembly.
    • With the ball inserted, route the steel cable through the assembly and align the black plastic notch on the cable with the plastic notch on the door pull handle assembly.
    • Press the cable notch into the door pull handle notch and snap it into place.
  2. 2010-Present Subaru Legacy Rear Door Reassembly: paso 2, imagen 1 de 1
    • Hold the door lock in the "unlocked" position with your thumb. This will make it easier to insert the metal ball into the door lock assembly.
  3. 2010-Present Subaru Legacy Rear Door Reassembly: paso 3, imagen 1 de 2 2010-Present Subaru Legacy Rear Door Reassembly: paso 3, imagen 2 de 2
    • Insert the metal ball into the plastic door lock assembly.
    • With the ball inserted, route the steel cable through the assembly and align the blue plastic notch on the cable with the plastic notch on the door lock assembly.
    • Press the cable notch into the door lock notch and snap it into place.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 691
