Saltar al contenido principal
2010 Toyota Camry SE Dome Light Bulbs Replacement
Qué necesitas
  1. 2010 Toyota Camry SE Dome Light Bulbs Replacement, Dome Light Bulbs: paso 1, imagen 1 de 1
    • Use one hand to push up on the roof surrounding the plastic cover and utilize a flathead screwdriver to gently pry out light fixture and cover.
  2. 2010 Toyota Camry SE Dome Light Bulbs Replacement: paso 2, imagen 1 de 1
    • Starting with the 2 clips on each side of the light, remove the 10 clips on the fixture.
    • The user should loosen every clip before removing fixture.
  3. 2010 Toyota Camry SE Dome Light Bulbs Replacement: paso 3, imagen 1 de 1
    • Once the clips are loose, pop off the plastic cover grey plastic cover.
  4. 2010 Toyota Camry SE Dome Light Bulbs Replacement: paso 4, imagen 1 de 1
    • Using hose pliers, pull out the bulb being replaced.
    • Now, insert new bulb by securing it into socket and pushing into place.
  5. 2010 Toyota Camry SE Dome Light Bulbs Replacement: paso 5, imagen 1 de 1
    • Reinstall plastic light fixture by pushing cover back into place.
    • Fixture should easily snap back in with proper placement.
  6. 2010 Toyota Camry SE Dome Light Bulbs Replacement: paso 6, imagen 1 de 1
    • Finally, test the new lights by turning them on and off a few times for 30 seconds or so to assure they work properly.
    • If they do not work then the next suggestion would be to check the fuse box before heading to the dealer.
    • Sometimes fuses blow out which can be spotted by careful analysis. If two parts of the fuse do not meet such as disconnected wires then you have a blown fuse.
Linea de Meta
Una persona más ha completado esta guía.
Un comentario
Hi, Thank you for posting this repair solution. Do you think it'll be easy to replace the entire assembly? My bulbs work, but the buttons don't stay on. Thanks.
KPW - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 36
Todo El Tiempo: 2,746
