Saltar al contenido principal
2010 Mazda 3 Windshield Wiper Replacement
Qué necesitas
  1. 2010 Mazda 3 Windshield Wiper Replacement, Windshield Wiper: paso 1, imagen 1 de 3 2010 Mazda 3 Windshield Wiper Replacement, Windshield Wiper: paso 1, imagen 2 de 3 2010 Mazda 3 Windshield Wiper Replacement, Windshield Wiper: paso 1, imagen 3 de 3
    • Turn on the wipers and turn off the car when they are at the apex of the arc. This will allow easier access to the wiper.
  2. 2010 Mazda 3 Windshield Wiper Replacement: paso 2, imagen 1 de 3 2010 Mazda 3 Windshield Wiper Replacement: paso 2, imagen 2 de 3 2010 Mazda 3 Windshield Wiper Replacement: paso 2, imagen 3 de 3
    • Grab the wiper and lift it away from the windshield.
  3. 2010 Mazda 3 Windshield Wiper Replacement: paso 3, imagen 1 de 3 2010 Mazda 3 Windshield Wiper Replacement: paso 3, imagen 2 de 3 2010 Mazda 3 Windshield Wiper Replacement: paso 3, imagen 3 de 3
    • Grab the wiper and rotate it 90 degrees.
  4. 2010 Mazda 3 Windshield Wiper Replacement: paso 4, imagen 1 de 2 2010 Mazda 3 Windshield Wiper Replacement: paso 4, imagen 2 de 2
    • Slide the wiper blade straight down away from the rubber of the blade.
    • Remove the wiper from the arm.
  5. 2010 Mazda 3 Windshield Wiper Replacement: paso 5, imagen 1 de 2 2010 Mazda 3 Windshield Wiper Replacement: paso 5, imagen 2 de 2
    • Take off the plastic covering at the base of the arm.
  6. 2010 Mazda 3 Windshield Wiper Replacement: paso 6, imagen 1 de 3 2010 Mazda 3 Windshield Wiper Replacement: paso 6, imagen 2 de 3 2010 Mazda 3 Windshield Wiper Replacement: paso 6, imagen 3 de 3
    • Lift up the wiper blade and rotate the wiper 90 degrees.
    • There will be some resistance, however you should not need to use a lot of force. If it does not come off easy you may be doing it wrong.
Conclusión
To reinstall the wipers slide the wiper in the opposite direction as taking them off.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 43
Todo El Tiempo: 936
